Question about Dual XDM-6820 CD Player
What are transit screws for a xd1225 and what will happen if u dont remove them
  • 635 Answers
The transit screws are for locking the CD mechanism when it is shipped from the factory. Most of the Car CD players have floating suspension for the CD transport mechanism. This prevents CD skipping when you are traveling off road or when driving on bad roads. The CD mechanism has four shock absorbers or dampers fitted underneath . The Transit screws tighten these dampers and make them stiff ( in other words no soft action ), so if you forget to loosen them and travel through a bad road the CD might skip. On good roads one might not even realize the difference.
Posted on Mar 28, 2011
2 Suggested Answers
  • 1335 Answers
SOURCE: what are transit screws for
The transit screws keep the components from moving and getting damaged during moving or shipping. The unit will not operate if these screws are not removed.
My machine is making a loud noise and shaking despite removing the screws at the back
Check your user manual, maybe there still screws not removed .
Dec 16, 2017 | Washing Machines
How do I remove the Transit Bolts?
Hi,I dont know about AEG but on some of the washing machines that I have done,I found that they are located on the back of the machine,and they just unscrew anti clockwise,and you should have some plastic blanks that go in the holes.
I hope this was some help,all the best.
Jun 10, 2015 | AEG Washing Machines
White knight cl372wv tumble dryer
-Are you talking about screws...? If so. Yes. It's on the back panel cover.
-Transit bolts are the bolts that hole the unit on a box crate only.
-After the unit has been set up. I think it already remove before set up.
Good luck
Mai
Dec 27, 2013 | Dryers
How to reset the speed limiter on a ford transit 2007 model 2.4 rwd
on top of in jection pump u will sea seal covering a screw shud b ..10 mill mm remove seal and turn screw out un till u have the speed u require but make sure u dont go to far as u will blow engin also u will have to adjust up the slack on cable ..make sure u tighten up when finished tight other wise it will viberate out and blow ur engin e trile and errow is best way to test hope this helps good luck
Sep 20, 2013 | MK7 COMROPE 50
My DVP-CX860 has never opened, only the ON button turns on and nothing else happens, since i bought it. Anybody can help?
Is there a transit screw in the bottom? It (they) need removing.
If you hear a little motor straining to open the tray when the open button is pressed, there is something jamming it. In a new machine, there are usually transit screws.
Read the manual, looking for unpacking instructions.
Jan 10, 2012 | Sony DVP-CX860 Multi-disc DVD Player
Mar 28, 2011 | Dual XDM-6820 CD Player
Unable to load library
looks like the error happens when you use a corrupted or bad specific transition in you production. I recommend you update your direct x drivers to the latest, also update your flash to the latest. Then if the problem persists, take the transitions out of your production, and troubleshoot by trying each transition until you find the one that causes the "unable to load library" error. (if the updates dont do it) check your direct x version and tests by running DXDIAG at the start run menu hope that helps you!
Aug 29, 2010 | Corel Video Studio Pro X2 for PC
Drum will not turn just bought it is there a transit bolt
check to see if the belt is off as dryers don't have transit screws
Oct 22, 2009 | Dryers
Transit brackets
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Mar 20, 2008 | Washing Machines
Dual XDM-6820 CD Player Logo
189 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
