Question about HP Officejet 4355 All-In-One InkJet Printer
I have a jewett set up on 4355 fax & phone when some person rings me it goes to the fax instead of the answering merchine can some one help me set it up please
    Guru:
  • 89 Answers
Check with your phone company if you have distinctive ring assigned to your fax
Ringing is having difficulty to distinguish if it is a ring for fax or a ring for call.
if you phone call is 2 rings then set the fax ring to 6
check for distinctive ring from your phone company either double rinfg,triple ring or quadrouple rings
I hope I help you a bit
Thanks
Posted on Mar 28, 2011
How to set for ringing setting
Good day.
I have a perfect answer for you. I am assuming that this question is with regards to the number of rings for fax messages,right?
Choose Setup Menu(that would be the wrench icon on the front panel) Choose Tools>Basic Fax Setup>Rings to Answer. Here you could choose the number of rings,and make sure to press OK to confirm.
Tip:The number of rings on the fax machine must always be two rings higher than the answering machine,if you are using one that is.
Jun 20, 2011 | HP Officejet 4355 All-In-One InkJet...
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
We cannot dail the fax or numbers
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Apr 12, 2010 | HP Officejet 4355 All-In-One InkJet...
Hp officejet 4355 fax is notreciving
make sure the phone lins is conncetd it is working and it is getting the call when someone call on that no.also check Fax: go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 20, 2010 | HP Officejet 4355 All-In-One InkJet...
I have an Office BX610FW printer/copier/fax. I
You just need to change the Rings To Answer option so that it is the maximum 9 rings. This means that that the phone will be allowed to ring 9 times before the fax answers the call. This option is found in the Setup menu, under Communications and then Rings To Answer. Hope that helps.
Regards,
Epson
Dec 01, 2009 | Epson Office Equipment & Supplies
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Incoming faxes
Do you have a distinctive ring pattern in the same phone line
If no then you need to get a distinctive rig pattern from your service provider, which will differenciate the type of rings for phone and fax.
If you have a distinctive ring pattern make sure which one it has single rings, double rings, triple rings and double and triple rings.
To enable> First make sure auto answer in turned On
In setup/Menu go to > Rings to answer and set it to 5 or 6, and make sure the rings to answer in you answering machine set to 4(Always Should be lower then you rings to answer in the fax)
In Advance Fax setup> Then Ring pattern should be setup for the one which you service provider as given either double or triple Rings>
And the go to tools and run fax test and check what has failed
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Phone line and fax line
If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
Also, you have to enable auto-answer on the fax machine.
Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
