I am trying to plug my Compaq Presario CQ60 Laptop into my LG RT-39NZ43RB TV using a VGA to S-Video 3 RCA TV AC converter cable with extension rca and s video cables coming off that into the AV3 side panel of the TV I push the fn and F4 keys together and nothing happens what am I doing wrong?
  • 961 Answers
I would think that you would hook your VGA male into your computer and would probably choose the s-video for video and us the red and white for left and right sound, if you didn't have s-video, you could se the yello for your video. i don't understand the F4 thing. Is that something special for the adaptor? Wouldn't you just check in device manager to make sure your onboard video and audio are enabled and working correctly? t shouldn'te any different than hookin up a monitor and the mputer won't know the difference.
Posted on Mar 28, 2011
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
COMPAQ CQ50-130US to tv with vga to rca
VGA is digital and RCA is analog. Might not work unless you get a converter or something.
Jan 07, 2013 | Compaq PRESARIO CQ50-130, CQ50-130US,...
How do i connect this compaq presario model to my sony tv?
you need to have a cable converter, VGA to component/rca output
Jun 05, 2010 | Compaq Presario CQ60-220US PC Laptop
How do I connect a presario CQ60-211ds to a Philips 42pfl3704d/f7
Hi, I don't know if you have sorted it out, but here goes.
I have a slightly different model to you, but mine has a HDMI output and my TV also has HDMI, just connect the 2 together whith a cheap HDMI cable, not need to spend a fortune and you should be sorted. There is another way and that is using the monitor ( VGA Connector ), but I don't think your TV has a pc input. I have just found this while typing.
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=42PFL3704D%2FF7&dct=QAC&new_tmpl=1&refdisplay=QAC_72673&refnr=0072673&scy=US&slg=AEN
Give it a read but basically the only connection you can use is hdmi unless you have a dvi connector on you laptop.
I bought a wireless keyboard and mouse and left the laptop near the TV so i can use it from my armchair.
Let me know if this has helped.
Tony
May 30, 2010 | Compaq Presario CQ60-212US Notebook
I have a laptop and a tv. I would like to hook my laptop up to the tv. The tv does not have a slot for a VGA CABLE and my laptop does not have a slot for an RCA CABLE. What can I do to connect the two?
You need an Video out, adapter cable, for your model Laptop, IF yours indeed does have the ability to TV out, the "output" is "Composite Video" and goes into the Composite Video "IN" on the TV. Audio is taken from Line Out in laptop & goes to AV audio in, via a Phono Jack to RCA converter plug. Also it must have correct drivers and be enabled and have desktop extended to the TV either Cloned or Spanned.
Usually one connects up to the TV, powers TV on & then Turn your laptop on.
You may have a Yellow RCA socket on the back/side of your laptop, otherwise you have to get a converter cable.
Feb 07, 2010 | Compaq Presario Notebook
In cq60 presario , how can i run tv
from the specs i have found if your trying to use it on the tv you will need a vga to s video adapter you can find it here http://www.amazon.com/TV-out-VGA-S-Video-Cable-Adapter/dp/B000P3UB24 if you need any more help please feel free to contact me at www.nittron.com
Nov 08, 2009 | Compaq Presario CQ60-220US PC Laptop
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
