Question about Toshiba Satellite P105-S6197 Laptop
I hit one of the function keys and locked up the keyboard Do you know how to unlock it?
    Scholar:
  • 113 Answers
Press the shift key and while holding down the shift key hit the f6 key located above your row of number keys,if that doesnt do it then look for a key on the top row that has a picture of a pad lock.Hope this helps,let me know,Thanks.
Posted on Mar 28, 2011
3 Suggested Answers
listeur
  • 88 Answers
SOURCE: keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Posted on Nov 24, 2007
SOURCE: How can I unlock the blue function keys on my HP Pavilion dv2000?
Hi, I had the same problem and found the solution on another website:
To turn on and off Bilingual blue keys:
Hit Ctrl + Shift + shift
(yes, both shift keys at the same time in addition to ctrl)
and that turns on and off the Canadian bilingual blue keys on HP lap tops.
It's so annoying and happens to me frequently. Hope this helps.
M
Posted on Dec 15, 2008
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
How to function Fn
Step 1:
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key. The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function. The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop. Use the drop-down menus on the support page to choose the specific product line and then model of your laptop. Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys. Find the sequence of keys you need to press to unlock the function key on your laptop. Press and hold the function key on the keyboard and then press the other keys required to unlock it. Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys. Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
b>
Feb 15, 2013 | Gateway NV52L06u Laptop PC
How do i unlock my keyboard
Best Answer: Look on your keyboard. On most laptops there is a function key that will lock the keyboard. You would need to pres the [Fn] key and key with the lock symbol
Aug 24, 2012 | Toshiba Computers & Internet
One day I noticed after my kid played with my laptop dell insperion mini 1012 that my keys stopped wprking. The mouse woorks and when I searched in the control panel it says the divice is working. It has...
Look at the top right hand side of the keyboard. See if the NUMB LOCK and FUNCTION LOCK keys are lit. If one or both are lit hit the key to unlock it.
Pressing the WINDOWS KEY and the letter U will bring up ease of access window. Down the list you'll see use without keyboard and mouse. Click there and make sure it is not check marked. You may also need to turn off STICKY KEYS and FILTER KEYS and hit save to unlock it.
Try pressing the WINDOWS KEY and the letter L at the same time and see if that doesn't unlock it. If that locks it instead of unlocking it press it again to unlock it.
If none of these fixes the problem then UNPLUG the laptop from the adaptor. Turn it upside down and remove the battery. Wait one minute then put the battery back in. Reconnect the power supply and reboot the machine.
Aug 16, 2011 | Dell Computers & Internet
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
Locked keyboard buttons
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Apr 20, 2009 | HP DC170B Keyboard
Function Key Issue
Your keyboard may have a function key lock (could be up in the right corner) that locks the keys in the Fn mode. Look for that. I have seen this on several keyboards. On some keyboards I've been able to get around this by hitting the print screen, scroll lock, or pause key to unlock it.
Jul 04, 2008 | Acer Aspire 5002WLMi Notebook
Panasonic Toughbook CF-51 laptop blue FN key locked on
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Jan 09, 2008 | Panasonic Toughbook CF-51 Notebook
Toshiba Satellite P105-S6197 Laptop Logo
176 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
