Monitor will not lit up. The only message I am getting is No Sync.
  • Robert Kitaji Mar 28, 2011
    Does the monitor turn on? or is it dead?
    Novelist:
  • 107 Answers
The cable connecting your monitor to your PC might be disconnected. Or the PC is not booting at all. Try connecting the monitor or connecting a different monitor to your PC to isolate the problem.
Posted on Mar 28, 2011
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
My samsung 750s monitor has a message saying sync. out of range
When you turn off the pc the monitor loses the sync signal and should go into a suspend mode where the screen is blanked. The power management settings should be checked. In display properties check that the monitor is installed correctly.
Jun 06, 2010 | Samsung SyncMaster 750S Monitor
No Sync message on the TV screen
Is the VGA port enabled? Have you set the computer to send data to the port? (The first may be part of the BIOS or the Device Manager. The second is in the graphics properties - right click on the desktop.) Reboot the computer to make sure it sees the new hardware with the monitor/TV on. Is the cable good? Try another one.
I hope this helps.
May 28, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Synchmaster 913 The unit displays 'Not Optimum Mode 1280 x 1024 60hz' after being run to approx 1 hour
Hello. That message appears when the video signal from the computer exceeds the monitor's ability to display it. If the sync is set too high(i.e. max sync on the monitor is 60 Hertz at that resolution), you will get that message. Check the video settings in control panel--("appearance and themes" in XP), go to the "advanced" tab and look at the refresh rate. Most computer video cards are able to far exceed a monitor's display ability. Don't exceed 60 Hertz--check the users guide for specs--the lower resolutions can have higher refresh rates(useful in games) Sometimes, a little lower video quality can yield a big performance difference in the display because the screen can update itself faster. (I use a radio control flight simulator pgm that is heavy on video ability).---Hope I was of assistance!---Rick
Sep 22, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
No signal detected
Check all of your cables - VGA / DVI mainly in the back of the monitor and the back of the PC.
Jun 09, 2009 | BenQ FP737S-D 17" LCD Monitor
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
Computers & Internet Logo
David Payne
David Payne
