Question about Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx USB
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
Alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
Posted on Apr 15, 2011
I cant get sound from fx send to my computer
Open the volume mixer on the pc and make sure the mic port is on. When you find it, click on the "advance" tab and there will be a check box allowing you to add 4db to the volume of the mic. Also, make sure it is plugged into the line in or mic input on pc.
Mar 16, 2013 | Behringer XENYX 802 Mixer
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
Dec 09, 2011 | Behringer XENYX 2442FX Mixer
How do i wire up an effects unit for the eurorack pro RX1602? It only has a mono/FX output socket.
In your user manual on page 7 is figure 3.2 wire your effects unit like the Virtualizer they show... driven by that mono/fx send and the the effects return returns coming back into unused channels...
Sep 13, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I have the Xenyx 2442Fx for about 6 months. I know it's still with in the warrenty period, but I have something rather strange happening to the digital fx on Aux 3. This is a bit of a long winded one but I...
This sounds like a breakdown in the digital circuits. You are seeing/hearing digital noise. This is most likely an IC that is breaking down internally. This will take some time to find/fix. Use the unit for your gig, then return it under warranty for repair. Pay close attention and note WHEN the problem occurs. If possible, try this multiple times and record any pattern to when it happens. The more detailed the "timing" the easier it will be for the repair shop to reproduce the problem and fix it.
Keep us posted.
Dan
Aug 17, 2010 | Behringer XENYX 2442FX Mixer
I need the part number for the volume slider on a 1832 fx mixer p
I don't think you require a part number for your mixer, ring the company and tell them what model you have and I'm sure they will be able to assist you in regards to your volume slider.
regards Col
Aug 02, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How do i set a behringa 1832 fx mixer
I have a behringer 1832fx mixer and have the manual that illustrates how to set up for a band and/or other instruments etc! is this is what your asking for?
regards Col
Jul 07, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Do I need to connect the Xenyx 1202 to an amp?
If you are the only person listening, you can use headphones with the headphone jack. Otherwise you will have to use some sort of amplification and speakers,e.g. P.A., stereo etc. I'm using a Xenyx 1222 FX and am quite happy with it.
Mar 22, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
159 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
