Question about Biostar TPower I45 LGA 775 Intel P45 ATX Intel Motherboard
Can you tell me what is the difference in performance without having Dual-Channel working as it should,compared to my present situation meening NO DUAL-CHANNEL working??
  • Anonymous Mar 28, 2011
    I do undedrstand you.I have 2 sets os 2 x2Gb Kits, they are Right types of memory,it is even printed a text in both casings- Dual-Dhannel kit- and they have new never been used before.I have all together 8Gb:s and a Win Vista 64-bit Memory are A-DATA DDR2 800Mhz
    Master:
  • 525 Answers
Dual channel means two channels of memory. there are two configurations you can use. you can use single channel method which has twoo ram sticks running on one channel or you can have a seperate channel for each ram stick. Dual channel is said to be the better way to run it because it increases speed of the ram. Now assuming you have 4 slots for ram. to use dual channel you have to run 2 sticks of the same value (MB) right next to each other. You cannot run 2 sticks of different values in dual channel mode. In the case that you do the sticks would pair together on a single channel. Hope this helps you better understand.
Posted on Mar 28, 2011
Just want to know if what is the maximum size of ram of my motherboard conroe presler fsb 1066 dual core cpu? i have a 1gb ram and i cant watch hd movies i have a dual core 2.8 ghz processor is the lack of...
Without the brand and model, I can tell you for sure the 4 GB at a minimum. With the exact make and model, I can give more details or you can go to www.crucial.com and run the system scanner, it will give you the specs for your system. (Including how many ram slots and the max you can install)
Jan 16, 2011 | Computers & Internet
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
WHAT IS THE DIFFERENCE BETWEEN THE INTEL CELERON 450 AND THE INTEL PENTIUM DUAL CORE
HI,
The celeron you are looking at is single core
The pentium you are looking at is dual core (this is the one you want)
They are both physically the same size, and have the same speed, but you will get ALOT better performance out of a Dual core. A Pentium Dual-Core is a real production chip, where the Celeron series is just the chips that weren't good enough to be Pentiums. Much cheaper in quality ENJOY! RATE THISOLTUION
RNJ VINOD KUMAR
Jul 15, 2009 | Dell Computers & Internet
I'm Confused about Dual-Channel, How to Activate/Enable it?
Check your user manual for the type of memory you can use. If your computer could use dual channel memory, I think it would come that way. Dual Channel is a pair of special compatable memory modules and only come in pairs. To buy two unpaired memory modules and hope to run them as Dual Channel is wishing too much. If they work, you're lucky, but most likely they will not work as dual channel.
If you are using those two different memory modules and they both work for a total of 3 GB then you can not do much better.
How many memory slots are in your Asus G1 notebook?
Jun 14, 2009 | ASUS G1 Notebook
I want to know about different cpu processor.how they are working and evolution of cpu processor
PROCESSOR IS BASICALLY KNOWN FOR ITS BEST PERFORMANCE AND SPEED. CURRENTLY AMD PROCESSORS ARE KNOWN FOR ITS BEST PERFORANCE AT LOWEST RATES. BUT IF YOU NEED A BETTER PERFORMANCE YOU SHOULD GO TO INTEL PROCESSORS. COZ TODAY INTEL PROCESSORS ARE THE WORLDS FASTEST PROCESSORS. THE ONLY LIMITATONS FOR THIS PROCESSORS IS ITS PRICE.
BUT IF YOU NEED TO PLAY GAMES AND WANT TO WORK IN MULTI TASKING YOU I ADVICE U TO SHIFT INTO INTEL PROCESSOR.
YOU CAN COMPARE THE BOTH PROCESSORS. JUST GO TO GOOGLE.COM AND TYPE COMPARE PROCESSORS IN SEARCH. THE RESULTS WILL SHOWS YOU THE SAME THING AS I SAID.
BYE
NICE DAY.
PLS. RATE MY SOLUTION.
KETAN
Feb 18, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
I can't find the Timing for Crucial PC3200 DDR 400mhz
Sorry to run dual channel memory both stick MUST be the same
Aug 19, 2008 | Intel Motherboard
New Installation
Are you sure the ram is compatible with the mobo? Try taking all but one stick of RAM out and see if it still does it.
The long beeps tend to point to a RAM problem, or it's possible it can't "find" a hard drive.
Some motherboards support dual channel (you'll see different color slots), and some don't. If you try to put the sticks in dual channel configuration, and the cpu or the motherboard doesn't support dual channel, you may experience this.
If you have different color slots, put one stick in one color slot, and another stick in the other color, or vice versa.
The manual "should" tell you the proper configuration for this, and may even tell you what the beeps stand for.
If you can post the make / model of all the components, I can do the "dirty work" for you and see it if should all work together.
Jan 08, 2008 | Intel Motherboard
Problem qdi p4i865 pro
Check your manual and find the QVL list. Memory tested to work in your board is listed there. I found a link that shows your board. Click the Download on the left & check your manual.
http://www.qdigrp.com/qdisite/eng/news/20030521.htm
You Max speed is 400Mhz memory as you will see at the link.
Please vote...
Dec 26, 2007 | Computers & Internet
Biostar TPower I45 LGA 775 Intel P45 ATX Intel Motherboard Logo
286 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
