Hi i have a jbs airmaster spilt air con model hr125pca/hr130pca and it goes on for around ten mins and the shuts down the flickers 7 times the booklet indicates external feedback failure, the unit is 2 years old and i thought there was a 5 year warranty, how bad is this problem and cost wise.
Sea Breeze
  • 4655 Answers
SOURCE: JBS Airmaster Split System 1.5hp is automatically shutting down
This is a close as I have been able to get your sources and information. I hope the link and the company will give you the answers you need. Anyway we will give it a try? Click the link below and please let me know if you were able to resolve the problems mentioned here at FIXYA
Let me know and Thanks
http://www.airmasters-ar.com/webapp/GetPage?pid=109#Source%20List
Posted on Feb 02, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: smell from Mitsubishi air conditioner
THE SMELL MIGHT BE FROM MOLD DUE TO HUMIDITY COLLECTING INSIDE THE UNIT NORMALY THE GAS A A/C USES IS ODERLESS OR MIGHT BE FROM STAGNET WATER INSIDE THE UNIT.
Posted on Mar 09, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 69 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off
Refrigeration problem. Must be a bad thermostat.
May 11, 2013 | Sharp AF-S120FX Air Conditioner
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Element HDMI 32 inch. Left half showing picture, right half only showing vertical rainbow lines.
One of 2 things happened here. Either your T-con board is defective and needs changed, or your Panel is defective and you need a new TV.
Apr 11, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Shuts down after around ten min.
Any electrical device which shuts down after a period of time is usually over heating. Turn the device off, clean out all fans and vents on the device with compressed air and move any other objects away from the device so that it has room to breathe. If this works then you need to keep the device away from other electrical equipment and keep the fans and vents clear for air to circulate.
Mar 24, 2011 | Samsung HTC550 Theater System
Won't download 1.5 update for ps3
It may be your internet connection, or you may not have enough space on the drive. How big is the file, and how long have you left it to run? if its a update for a game like a expansion pack, it may be around such and such GB and depending on you internet connection it might take up to a hour or two.
Regards
Jul 22, 2009 | Sony PlayStation® 3 (80GB) Console
JBS Air conditiong went bust early 2007. but there is still ways to get around this. you can try switching off the mains to the unit for about an hour then back on see how this goes as it resets the electronics. common fualt with JBS. other wise you can contact me on 0412 844 991 as i still have some contacts that may be abl to help you out.
Feb 02, 2009 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
