Question about Creative Labs Zen Touch MP3 Player
Hard disk problem?
Hiya.
I have a creative zen vision M 60gb that has stopped working. When I turn it on it boots up fine but switches to recovery mode where, in red box it writes, Creative Zen Vision:M (DVP-HD0004)
under that is writes, v1.20.02_0.0.25
Under that it gives me the followling options:
clean up
format all
reload firmware
reboot
Since this problem, I've tried each of the 4 options above but nothig seems to work and the mp3's response is HARDDISK PROBLEM! I've also downloaded your mp3 recovery tool and up graded my creative source media 5 system to your latest verson and still nothing works. What should I do? I live in Dublin, Ireland, is there somewhere I can bring the mp3 to be repaired? Please help...Mark
  • sheing Apr 13, 2009
    hello mark..i had the same problem..i try anything but nothing happen..hope someone will help us here..
Hi mark,I have same problem..recovery mode nothing works .. i live in australia and not sure yet who fixes it telss you about firmware download..have not tried yet..this is only something new.will try more things and post again Good luck Helen
Posted on Aug 04, 2008
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
My creative zen screen wont light up its dark i tried the light up feature but no luck
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
hope this helps you
Jul 24, 2009 | Creative Labs ZEN Stone MP3 Player
My creative zen vision M says FIRMWARE PROBLEM! HELP!
Hi you can try going to Creative's web site and downloading there Creative MP3 Player Recovery Tool software and what that does is update everything and most of the time it will fix what the problem . I would try that first.
I hope this helps
Mar 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Firmware problem for zen vision M
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Touch firmware problem
This means both systems contain a bug, or cookie. If the firmware you accessed isn't applying itself to the device, this means the system itself has been corrupted. Double check with your system configuration properties on each device, and tell me whats going on from there.
Don't panic!
bananaboy101
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
ZEN VISION M STUCK IN RECOVERY MODE
im having that sme problem! even when i try 2 restart it still acts crazy! when u find out how 2 fix ur let me kno cuz really want this thing 2 start workin again
Mar 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M 60GB
Go to creative's website, they have an auto fix tool.
here ya go^^
http://us.creative.com/redirect.asp?id=5857
Jan 09, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
I can't say this will work for you, but I had exactly the same problem (I think the clicking noise has something to do with the hard disk being slightly dislodged - possibly after dropping it?). I found that giving the side of the Zen a sharp smack on my knee sorted it out.
Apr 14, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Touch MP3 Player Logo
291 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
