My monitor become white and no information - Computers & Internet
    Problem Solver:
  • 12 Answers
Try to do a factory reset on the monitor by pressing the menu button
if still have the same issue then connect only the power cable to the monitor and check if you get a white screen then the monitor needs to be replaced or repaired
and if u dont get white screen the issue could be with graphic card
Posted on Mar 28, 2011
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computers & Internet
Lcd becomes white
When a monitor becomes white, that means there is a problem with a capacitor or capacitors on the monitor's motherboard. These capacitors will be noted by their bulged top heads or they will be leaking. Capacitors work to hold down power from the source and keep it long enough for your display. And if any of these capacitors are bulged or leaking, they might not hold the power long enough or the screen will always be white. Find a technician who can open it up for you and carefully replace the capacitors
Sep 09, 2013 | Computers & Internet
Monitor become white
since you have not replyed with more information im marking this as solved .
Dec 21, 2011 | HP L1908w Monitor
My F-19 screen become black .Can't see on TV or PC, just sound on TV connection
pradzevalqim, Monitor may have problem with internal switch-mode-power-supply / ccfl inverter lamp supply" causing fluorescent lamps to not light-up and provide "white light" so you can see what is on the glass lcd panel. You or qualified technician will need to investigate and repair the unit. Read my fixya profile for more information about "black" or "blank n black" screen repair. 12fixlouie
Sep 08, 2010 | Acer Ferrari F-20 20" LCD Monitor
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
Computer monitor doesn't show colors good only white and blue
Drivers not installed properlyu...install properly the driver, if then same proble check the VGA card for the desktop/ vga chepset chep in laptop.. or cable connection og vga...
May 31, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
How can a dummy degauss this problem?
Degaussing is only an issue with CRT monitors, I'm afraid the monitor is going.
Apr 01, 2009 | Westinghouse L1928NV Monitor
White screen display
Appreciate the direct "Ask Me".
Often, problems such as this is indicative of a failing capacitor in the 5V internal regulator section. Most capacitors uses a wet dielectric that dries out after some time due to heat buildup. In some instances, most of the capacitors would also fail ESR test. Additionally, you may want to check the external power supply if it is putting out the correct voltage as indicated in the reverse of the adapter box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
