Question about Fisher Paykel EcoSmart GWL15
Hello, I have a MW612 Fisher and Paykel Washing Machine. Yesterday it was about to spin out and stopped and started beeping at me showing the first and seventh lights flashing on the display. Called Fisher and Paykel and was advised this fault is a Water Valve Circuit problem and requires a Technican. Before I faulk out money to sort this, I am wondering if this is something I can fix myself? Thanks
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Posted on Mar 02, 2009
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
I have a MW612 fisher and paykel washing machine. I turn it on and the 3rd, 4th and 8th lights turn on and start beeping. Nothing stops it until you press start and then the lid lock light comes on and...
all tho the manual says a faulty cold water solenoid which it can be i have found that 9 out out of 10 times its not tht but a faulty main contol module
Dec 07, 2013 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi, My washing machine, Fisher and Paykel, MW 511 PRIDE would not do the SPIN cycles. Please advise. Thanks. Sam Lee
Hi Sam Lee.Now , does the machine drain the water?If it does drain the water does it stop and beep and show an error code?if it does the error code will be a series of lights that will light up when the machine is beeping.They will be on a row of 8 lights.Starting from left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 03, 2010 | Fisher and Paykel Washing Machines
Bought the washer and dryer set about 5 years ago and have been very happy with the brand. Starting yesterday, the 29 of june the machine will not go into the spin cycle. It does everything up to that and...
Hi just read your posting.Now does the machine drain?When the machine stops does the machine beep and show an error code in lit lights?Please reply with additional information and I can help you rectify this fault.
Jun 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
146 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
