I have an Epson Workforce 630. Set up was quick & easy. I sent a test fax to my friend, he sent me one. Everything was ok until I picked up the phone line a couple of days later (today) only to hear a continous tone. I turned off the machine and unplugged the line, wated about 10 min. and plugged in and turned on everything. It now works fine. The phone is not hooked to the machine but hooked up in another room.Q: Should I turn the ECM and or the V.34 settings off to prevent this kind of thing from happening again? I use this "twisted pair" for home alarm and must be clear. What do you think? Thank you very much! RT
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
SOURCE: Lexmark x215 printer/fax/scanner
I have an X215 also. It is not built to suit a duo line hence no fix is available.
Posted on May 23, 2008
  • 234 Answers
SOURCE: HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
Have you checked with your service provider about sending fax from VOIP lines.
Because iam affraid HP does not support VOIP Services.
Even if you call HP Tech Support they will ask you to call your VOIP Service provider they should have a answer for that.
Because the HP Fax machine only supports Analog signals and the VOIP Services have Digital Siganls which the machine cannot recognise, So please contact your VOIP Services for the same to send send faxes because it is not the fax machine which cannot send fax it is your VOIP Service provider which has a problem.
Good Luck
Posted on Aug 31, 2008
  • 5 Answers
SOURCE: epson stylus photo tx810fw printing problems
Reinstall the printer software.
Posted on Dec 25, 2009
Rider On Way
  • 1679 Answers
SOURCE: will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Posted on Jul 01, 2010
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
Workforce 630 paper jam
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
Jun 17, 2017 | Office Equipment & Supplies
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson workforce 630 driver install
you can download the drivers from the following link.
Oct 21, 2011 | Epson WorkForce 600 All-In-One InkJet...
I cannot figure out how to get a confirmation receit showing my fax was actually sent. How do I do this? Thank you.
You need to turn on report printing in order to get a confirmation page that shows your fax was sent. to change the settings you press the menu key and then use the arrows to navagate the choices until you see fax set up. Then you press "ok" or "enter". Then use the arrow keys again to scroll the choices until you find reports or confirmations, and then again press ok or enter. Then use the arrow keys to change the reports that print when a fax is sent and save your changes by hitting ok or enter. Then try a test fax to make sure the report prints and your done!
Jun 13, 2011 | Epson Office Equipment & Supplies
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
80 people viewed this question
