Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
    Scholar:
  • 80 Answers
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Posted on Apr 04, 2011
Paper not feeding through - paper jam
You are probably putting too many pieces of paper into the tray, forcing more than one piece of paper to get sucked into the printer and jamming
Aug 10, 2012 | Canon PIXMA iP1800 InkJet Photo Printer
Paper not feeding through properly, then jamming.
try to clean the back part of the printer.... maybe there some dry molden ink... that make your paper jammed
Aug 30, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 will not feed paper...One side jams and when I take the paper out, the jammed corner of the paper is folded under.
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Jun 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
PAPER FEED NOT FUNCTIONING PROPERLY. IT STARTSTO TAKE THE PAPER
its the roller with the rubber maybe. i do not know what that is called but my printer (1880) experienced the same. i found out the shaft of the roller is broken. this i did:5794815.png
Dec 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
237 people viewed this question
old marine
old marine
