Switch not responding to ping commands what would the problem be?
  • KyleONU Mar 28, 2011
    Could you please provide more information on what you are trying to do?
    Ping is a great way to diagnose connection problems, but is generally used to check against a well know site (such as your favorite search engine). Is the switch a managed switch? What are you trying to accomplish?
    Thanks.
  • aussie66 Mar 28, 2011
    I'm trying to make up a scenario to find what sort of things could cause a managed switch not to respond to ping commands.
  • 63 Answers
If the switch is turned off, then this could also happen, also some switches and other network devices will allow for settings to be changed to modify this sort of behavior. In all fairness, that would then be disabling some of the systems that make it a "managed switch", but you might look into those possibilities. Since some routers and switches use a version of Linux, it could also be a situation where they were modified at a low level to change some of their core behavior. I'm not sure if these ideas are what you are looking for, but hopefully they can help somewhat.
Posted on Mar 28, 2011
Testimonial: "great thanks for that ur a gem "
  • Edgar De Leon Mar 28, 2011
    other answers maybe
    - management VLAN not configured
    - the port still is in negotiation of speed and duplex
    - the host makng the ping has an ARP published to another device
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
It could be many answers to this issue - an acl on the switch - damaged cable - the switch and the pc are connected but with different networks/vlans defined - etc
Testimonial: "thank you for that if there are any other ideas you could think of please let me know"
    of what kind of switch we are talking about?
    any kind of managed switch not just 1 in particular
  • 54 Answers
The switch will only respond to a ping if ICMP packets are enabled and the switch is configured to respond to a ping. Many times, the network admin will turn off ICMP, which may look like there is a connection "problem" but intended functions are not compromised at all.
Bruce
Posted on Mar 31, 2011
How to Make a Ping Utility on Windows NT Systems?
Helps in determining TCP/IP networks IP address as well as determine issues with the network and assists in resolving them. See the ping definition for a full description.
Pings the localhost. which helps determine if the computer can send information out and receive the information back from itself.
Note: The above command does not send information over network, but can indicate if the card can respond .
Ping supports the ability to ping an Internet address. In the above example, we pinged "computerhope.com" and as can be seen, received four responses back. If we couldn't reach the server or the server was blocking our request we would have lost all four packets .
Allows you to ping another computer where <69.72.169.241> can be the IP address of the computer you want to ping. If you do not get a reply or get lost packets you have a problem with your network, which can be a cable issues, network card issues, drivers. router. switch. or other network problem.
Oct 20, 2016 | Computers & Internet
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
Aug 01, 2016 | Computers & Internet
I can't ping my router
Your router may be set to not respond to pings. Are you sure you have typed the correct address? From a command prompt (open start menu and run cmd.exe from the run box or search box, depending on operating system) and type ipconfig to see the gateway ip address, which is the address of your router.
Jun 05, 2013 | Linksys Computers & Internet
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
I have a mfc-7340 and a Blekin 4x4 peripheral switch. I have 2 computers hooked up to the switch. The switch recognizes both computers and the printer. However, I can only print from the first computer in...
reinstall driver again in seconds computer from where you can't aboe to give print.
Also check ping command
"ping (printer ip addreses.)
If you get reply from printer ip addrees with ping command then yourt printer is in network with your computer otherwise you have to correct your computer ip adreeess as your network settings .
Aug 23, 2009 | Brother MFC-7340 All-In-One Laser Printer
My internet is connected but I cannot view internet pages. I have tried various browsers to no avail. I have done a system restore that also made no difference.
sounds like a fire wall issue... do you have zone alarm or windows firewall turned on or norton internet security or mcafee?? try disabling them completely .... then you will have to go back and fix the rule that blocked you from getting on the internet you'll have to look through all the rules created recently
Jul 24, 2009 | Computers & Internet
Managed switches not responding to ping commands.
switch not responding to ping commands. hiow do i find out what the problem is
Mar 13, 2009 | 3Com 3C17210 /RETAIL3COM SS III 4400...
Pc to pc
follow instructions for setup.
1. in your computer network adapter TCP/IP settings, set into "Obtain as IP address Automatically".
2. do the same(step 1) in other computer
3. after saving the settings you should have now a network for two computer thru router.
4. one of your computer should have an IP 192.168.0.2 or 192.168.1.2 as most of router default IP series is 192.168.0.0
5. if you have this series of IP for both computer you have already a network
6. to test if both computer is communicating run this command at DOS or Command Prompt( click start, run and command the click OK
7. at DOS command prompt type PING 192.168.0.2 (ping the IP address of the other computer in your network)
8. or you can also ping the computer name like PING mycomputer(your laptop or desktop computer name)
9. successful PING should have a "reply from" results.
Hope this will help you
Nov 24, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
HP 9040n NOT RESPONDING
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Feb 28, 2008 | HP LaserJet 9040n Printer
Computers & Internet Logo
257 people viewed this question
Alun Cox
David Payne
David Payne
