Question about Refrigerators
Kenmore 59673502200 french door bottom freezer will not cool nor build ice in freezer. i hear a relay clicking but makes a weird noise like a motor trying to start.
    Problem Solver:
  • 6 Answers
Sounds like the start relay on the compressor
Posted on Mar 28, 2011
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
Freezer blower is on and I hear a relay kicks in at the bottom but the freezer is not cooling . advice
The clicking you hear is from the overload. The relay is solid state so makes no noise. Change the
Relay
Jul 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Grrr noise that stops when doors are opened
The noise you are hearing is probably the fan blades hitting some ice build up. Un plug your refrigerator for over night and it will defrost melting the ice. If it still makes the noise after that then the fan motor is going bad, you will need to replace it soon. The reason that it stops when you open the door is because the power is cut off to the fan when you open the door.
Nov 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Motor noise and flashing light
The problem you may be having is an ice build up. Defrost the unit and take out the back wall of the freezer. Cut the insulation off as in the picture and it will solve the problem. What happens is a little bit of water gets trapped and then over time it becomes a massive ice ball that can block the fan. First you hear the ticking noise and then you get ER FF error.
Sgt 48
May 16, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
