Question about Miele W304 Front Load Washer
2 yo Miele w3725 machine has no sign of life after using a generator. Could it be the fuses? If so, where would I find the fuses please? Thx Donna
4 Suggested Answers
SOURCE: Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
Posted on Nov 05, 2008
blueextc3221
  • 15935 Answers
SOURCE: our miele w3725 is coming up with drain default
You'll need to clean the filter and/or remove the hoses to inspect the inlet strainer & clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
b_lea76269
  • 61 Answers
SOURCE: How many years of life can a Miele washing machine be expected to have with moderately heavy use?
8 TO 10 YEARS IS A GOOD GUESS
IT'S A BIT LIKE SAYING HOW LONG WILL I LAST
K SERRA SERRA
Posted on Nov 15, 2016
Hi I have a Miele w3725, press power button, washing machine stays on for 20 seconds then goes off, what could this be, cheers in advance Johnny.
Machine has not finished it cicle reset to zero. Take power off.wait a couple of minutes riconnect power run a small cicle.this is assuming water pump is working and filter is clean have you checked this?
Dec 06, 2017 | Miele Washing Machines
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Dec 10, 2016 | Miele Washing Machines
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
Miele W3725 washing machine appears dead. No lights on control panel. 240V AC wall socket is OK. Is there a fuse for power coming into machine? Can't seem to find one.
go to google and type in miele washing machines on one of the pages you will find a contact us tab
make a call to a service department and they will advise over the phone
May 12, 2015 | Miele Washing Machines
Miele w3725 won't start
If the Start LED keeps flashing, either the door is not closed properly, or the door switch is broken.
Mar 01, 2015 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
Our miele w3725 is coming up with drain default
Jun 29, 2009 | Washing Machines
Miele W304 Front Load Washer Logo
74 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
