Question about Connex Radio Communications
I have a connex 4600 turbo very good radio!! But the other day I keyed up my mic and the radio shut off but came right back on when let go. Do u know what that might be?
    Novelist:
  • Connex Expert
  • 500 Answers
Check for any loose power connections.. ground connections.. loose coax.. also make sure vehicle is on so not to drain battery down when TXing. if it was off it may have dropped battery voltage down lower than it should... and turned off.. RX doesn't use hardly any ampres..
Posted on Mar 29, 2011
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I would say yes it has a large heatsink. The variable might be the tuning. But if it's amp is not being pushed any harder than factory you will be fine. Nice radio I prefer them over the 4400turbo and the 3600hp it has the board like a 4300 not the 3300s like the fore mentioned.
May 26, 2014 | Connex 4600 Base CB Radio
What is the best power mic for the ranger vr 9000
Astaic 36L. You never want to run a power Mike with a good radio with Mic Gain. Road King is great to. It is very hard to find the honey spot with a power Mike when you have Mike gain on radio.I think it is pretty hard to beat the 36L. I use one one my Connex 4600 Turbo and Galaxy 95T2, They both performe great. Connex is a little better a DX ing though
Nov 22, 2013 | Ranger VR-9000 Base CB Radio
When i key the mic it squeals
turn down your mic gain and that should cure it.
Mar 18, 2013 | Connex 4600 Base CB Radio
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo radio stays keyed up even with mic disconected
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Mar 28, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo. Poor receive. About 4 mi.
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
May 20, 2009 | Connex 4600 Base CB Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Feb 10, 2009 | Connex 4600 Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
135 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
