I want a adaptor 230vav input &16v output power 3amps 48 watts where can i get it mumbai for my philips tv as i have lost the adaptor give me the ad where i can find it in mumbai of even thane as i live there
    Brigadier General:
  • 8,909 Answers
There are many listed on ebay.
Posted on Mar 28, 2011
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
Can I use an 18 volt universal AC Power Adaptor on Fujitsu Lifebook P7120 which is a 16 volt laptop?
With voltage step down power supplies, output power is more important than data plate output V (volts). V times output A (data-plate amps) equals output Watts (or VA) under normal load. If the voltages are close and the output watts (VA) are very close (one or two watts) you are in luck as long as the connector is same size; AND THE POLARITY (+ & -) IS THE SAME for the old and replacement unit!
Jan 17, 2012 | Fujitsu LifeBook P7120 Laptop AC Power...
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
Acer Scan prisa 620U Power adapter is missing. Pls tell me about its picture and its voltage. Thanks Azeem
my scaner power adaptor is missing input :220 v -output:16v 0.9A. IF I USE adaptor input 220v output:16v 3A is there any damage happned to my scanner.plese help me
Aug 15, 2009 | Acer Office Equipment & Supplies
I need the amount of amps used for multiple pieces of equipment
I'll hazard a guess that you are trying to run these things off of a single household electrical circuit and want to avoid an overload. In that case, the best way is to determine how many Watts each device uses. That information can either be found on the back/bottom of the unit, or on the AC adaptor that came with it. In the latter case, use the "input power" value.
Once you know the wattage, divide by the input voltage - 120 Volts in the US, 100 Volts in Japan, or 240 Volts in Europe, Australia, and much of Asia.
For example...the info on the bottom of my boombox indicates 120V at 16W...
Watts / Volts = Amps
18W / 120V = 0.15A
In another example, my laptop power supply has the following info...
120V-240V @ 160W input
15.4V @ 145W output
I use 120 Volts here so the math goes...
160W / 120V = 1.333A
Note that the output values are not used.
If I want to know how much current the devices use together, I merely add them...
Boombox Amps + Laptop Amps = Total Amps
0.15A + 1.333A = 1.483A
I hope this helps !
Marco
Feb 04, 2009 | Nikon CoolScan 9000 ED Film Scanner
Power adaptors/ travelling/ aptop
Yes, it is a switching power supply meaning that it automatically detects 120v (US) or 240v (EU) voltage. The only thing you might need is an adapter to convert the actual plug in from US to EU standards; they can be picked up for just a few dollars.
Thanks for using fixya and please take a moment to give this solution a rating of fixya. Thanks! :c)
Feb 02, 2009 | Sony VAIO PCG-K35 Notebook
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
