I have a sonic qmedia set top box model DVB16 and have lost the manual and cant set up the set top box to get digital tv. is there an easy solution..cheers..Norm
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 28, 2011
Why does it display "no signal" when requesting to watch tv ?
If I know the Sonic TV model, there is NO TV tuner built-in.
What sources have you connected to which port ?
Typical sources are
(a) Cable using Set top Box using HDMI
also see
Soniq tv problems
Mar 22, 2016 | Televison & Video
What code do I use for TV brand Tevion model AJ-19LHC3 as all the codes in the audio sonic user manual,do not work
2696,2661,2604,2600. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 01, 2015 | Universal Remote Control Televison & Video
I have lost the av channel and cant get it back
Not sure why you would need the AV channel. As long as the tv is switched on before the set-top box it should automatically show the video content as soon as the scart receives input.
I have not used the AV channel on any of my tv's since the digital switchover.
I am still using vhs tapes, a dvd player and a dvr top-box and use a multiway scart switch to select which to input to the tv scart.
Feb 20, 2015 | Televison & Video
I have a Universal Remote Control model huayu rm-68e+ and lost my manual and i need it for my kolin tv can anyone know the code for my Kolin TV in these universal remote brand tnx
If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check this link too. http://electrohelponline.blogspot.com/.
Don't mind about the brand name of remote control. Look for codes to your TV brand, whether it is 3 digit, 4 digit or 5 digit; whatisover.
May 02, 2013 | Televison & Video
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
Is this model digital
You don't say which model or make the TV is and we are not mind readers at FixYa.
However most TV's made that are digital have on the menu somewhere digital and analogue, because they have two tunners. If you look at the set-up menu and don't see digital set-up or something like it, then chances are it's not digital. If not then the only way you can watch this TV is with the box you mention.
Feb 01, 2010 | Televison & Video
DGTEC top box,DG -HD8710, lost manual when moving
The main aerial goes into the box,then a flylead out of the box into the tv(if you have a vcr or dvd rec then it will go in there first then out into the tv).Then connect the box to the tv with a scart lead.
Nov 07, 2009 | Televison & Video
Lost some stations on my Sony lcd TV.
It is a possibility if you are using a cable tv service, without a converter box, that the cable company has limited the number of station you are able to receive. It seems to be their new ploy to get subscribers to get a box since the digital changeover. I also may be that the TV's tuner memory may have to be re-programmed. Go into the menu and go through the channel scan process and see if they return. If they don'y it may be a tuner issue. An easy fix is to get a cable box!
Hope this has been helpful
Jul 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
I need a user manual for audio sonic TV Mocel KM 1427 please
need to retune my sonix15"tv model so15 i cant find the booklet
Nov 18, 2008 | Sony Part 996804671 Service Manual for...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
