Question about Dell 22" SP2208WFP Widescreen Flat Panel Monitor
Vertical lines (about 1 cm thick and 5 cm apart) have appeared on screen, more visible in the center and right side. The lines started off being very light, but of late have become more and more visible, showing vibgyor colours as well.
  • 83 Answers
It's going bad. Contact the manufacturer to see if it's still under warranty, you may need the receipt if it is under warranty.
Posted on Mar 28, 2011
  • bruceleemani Mar 28, 2011
    Found the documentation on my purchase online, and it appears I've had the foresight to apply for the 3-year warranty - which runs out July this year! Huzzah. Thanks.
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony Bravia 32in ... vertical gray line on right side of the screen about 4in from the edge of the screen. The line is about 5mm thick and present on all inputs. More visible over brown and blue...
The line should be visible, even with the television off. It is called "de-lamination" of the LCD panel, and occurs in lines, usually vertical, on the screen.
The panel does need to be replaced. You can contact Sony at 1800-222-SONY. They are good people, and should be able to help you.
Hope this helps...
Jan 05, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical Lines in Monitor
Try changing the refresh rate.
Jun 02, 2008 | Computers & Internet
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Dell 22" SP2208WFP Widescreen Flat Panel Monitor Logo
187 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
