Question about Vacuums
I recently purchased the stanley HIDO 109, 35W spotlight. Input 12 volt DC. The product had the vehicle charging unit but not the in home AC to DC charging unit. Nor did it have instructions in the sealed plastic packaging. My question is where can I get the instructions and the in house charger. Thank you, Ruben Leon gunslinger@cableone.net
2 Suggested Answers
Asbestos 56
  • 191 Answers
SOURCE: My simer ace in the
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Posted on Jun 09, 2011
How can I tell if my Dyson DC 35 cordless uses 220 volt as power supply to change battery. The one I purchased is advertised to do so. This is because I purchased it to use in the Philippines
Your devide should have the indications on electric input on a small plaque. Actually, it it's cordless, it works with a rechargable battery so most probably you should look at the charger unit. Probably it's 110/220V and has a swith somewhere,
Don't you have a user's manual?
Read here, might give you some clue:
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC35_Manual.pdf
Aug 02, 2015 | Dyson Vacuums
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
I have replaced the circuit board twice on my hayden 2400 and after working for 24 hours the circuit board then fails, with no signs of it tripping. Everything is wired in correctly the supplier is unsure...
Disconnect the wiring from the unit, and go back and plug in your hose.
Get a volt tester and test the voltage coming from the lines at the machine. It should read 0 volts. Check both AC and DC voltage.
Also, check the same setup if you have a security system. Arm the security system (or have someone do it for you) and test the voltage at the line again. Again it should read 0.
If both come up 0 volts, the security and the hose I mean, unplug the hose and try one more time again AC and DC volts.
The only other thing i could see it being is a problem with the motor, if the unit is 7-10 years or more, it may need a set of motor brushes for the motor.
Let me know how this goes.
Mark
Nov 08, 2010 | Hayden Industries SuperVac 2400 Central...
I have an electrlux pront stick vacume which no longer hlds a charge Is it true that there is a recall of the battery can I get a new battery since my husband the enginneer has diagnosed the problem as the...
Hmm..aug 02 2010...you probably resolved this..if not...http://www.cpsc.gov/cpscpub/prerel/prhtml09/09169.html also check the out put of the transformer...it should put out 15 volts...NOT 23 volts like mine. Saw the transformer on e-bay...http://cgi.ebay.com/NEW-15V-200mA-0-2A-AC-DC-Power-ac-adapter-Power-supply-/290372975461?pt=LH_DefaultDomain_0&hash=item439b93fb65
Aug 02, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Vacuums Logo
95 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
