Question about Aiwa JAX-S5 CD Shelf System
Hey, So I have had this shelf system for years, and have loved it dearly. It has worked flawlessly until a couple days ago. I usually keep it turned on, with the volume around 20/30 set to aux for my computer. I realize that this is probably the cause of the problem. Needless to say, I went to use it the other day and it was on standby (red light on the power button was on, the display wasn't). I pressed the power and it made it's usually clink sound, the standby light went off for a second, the light in my room flickered (which I think is usual, but could indicate a short), but then it turned back off. The display never came on. I'm am thinking that there is some kind of issue with the power supply or maybe there is a short somewhere, any ideas? common problem?
    Top Expert:
  • Aiwa Master
  • 45,984 Answers
Probable power supply failure
Posted on Mar 20, 2017
4 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Power Problem? My DS55 red standby light blinks at me and won't turn on.
I agree with your diagnosis. If one channel quit and the unit now ocassionally won't output at all then the amp is going into protect. Have it serviced.
Posted on Sep 22, 2007
  • 4234 Answers
SOURCE: AIWA shelf system volume button
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Posted on Dec 23, 2008
dunnbiker
  • 8546 Answers
SOURCE: i own a Aiwa NSX
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jun 23, 2011
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2014 | Water Heaters
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Wont power up
amplifier ic need to replace. remember use same # ic. good luck!
Apr 26, 2010 | Panasonic SC-AK90 Shelf System
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Dear Sirs: I have a Weiser keyless locke
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Disc Drawers will not open
There maybe a CD stuck in the mechanism or it may need to be mechanically reset. Not much you can do except take for repairs.
Jan 05, 2008 | Sharp CD-ES9 CD Shelf System
Half Dead Monitor
Dear
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
May 18, 2007 | Neovo F-417 17" LCD Monitor
CD tray doesn't open
if the unit actually tries to open but does not, it is not locked. a locked unit does not even try to open. it sound like a mechanical misalignment. take it back to get a new one, since it's only 2 days old.
Nov 12, 2006 | Sony CMT-CPX22 CD Shelf System
Turns ON but switches OFF immediately
that happened to me about a year ago, and i think it happened after a storm. i must have sat there and turned it on at least 50x. so finally i just left it unpluged for about an like a day. pluged it back in and it worked.
Nov 04, 2006 | Kenwood XD-A75 CD Shelf System
Aiwa JAX-S5 CD Shelf System Logo
51 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
