How many mm is 5cms? - Office Equipment & Supplies
  • 46 Answers
50mm = 5cm
1 Millimeter = 0.1 Centimeters
Millimeter (mm) To Centimeter (cm) Conversion Calculator:
http://www.translatorscafe.com/cafe/units-converter/typography/calculator/millimeter-%5Bmm%5D-to-centimeter-%5Bcm%5D/
Posted on Mar 28, 2011
Where can i find the radio code for my renault kangoo van
If you feel confident to do so, remove the radio and make a note of the serial number and maker then replace the radio. Do a google or web search for " Car Radio Codes". Select a site, usual cost is Euro10 and in a very short while you will receive an email with the correct code to unlock your radio
Jan 31, 2015 | Renault Cars & Trucks
Suggestions for a place to ground the amp 2002
run a 30 amp rated wire ( use black) and run from the amp to the battery negetive pole , put an inline fuse (10 amp) about 5cms from battery connection to protect the amp from power surges etc
Oct 18, 2014 | Cars & Trucks
Suzuki impulse GSX400X
Here is specs for those carbs
- AISAN AS27VW
I.D. No. - 04A10
Bore - 27 mm
Idle r/min - 1300+/-100 r/min.
Fuel level - 9.0+/-0.5 mm
Float height - 20.5+/-1.0 mm
Main jet - #94
Main air jet - 1.2 mm
Jet needle - 5B10-3rd
Needle jet - 2.60 mm
Throtlle valve - 11.0
Pilot jet - #34
By-pass - 0.8,0.8,0.8 mm
Pilot outlet - 10.8 mm
Valve seat - 2.5 mm
Starter jet - GS1 #60, GS2 #54
Pilot screw - PRE-SET (2 turn out)
Pilot air jet - 1.35 mm
Throttle cable play - 0.5 - 1.0 mm
Choke cable play - 0.5 - 1.0 mm
Aug 27, 2014 | Motorcycles
Kawasaki zzr1100c what is the valve clearence
hi there,
this table will help you. I used to own one.. beautiful bikes easy to work on too!
Valves:
Valve clearance: Inlet 0.13 0.19 mm
Exhaust 0.18 0.24 mm
Valve head thickness: Inlet 0.5mm 0.25 mm
Exhaust 0.8mm 0.5mm
Valve stem bend 0.05 mm TIR
Valve stem diameter: Inlet 4.975 4.990 mm 4.96 mm
Exhaust 4.955 4.970 mm 4.94 mm
Valve guide inside diameter 5.000 5.01 2 mm 5.08 mm
Valve/valve guide clearance
(wobble method): Inlet 0.02 0.07 mm 0.18 mm
Exhaust 0.06 0.11 mm 0.21 mm
Valve seating surface:
Outside diameter: Inlet 30.8 31.0 mm
Exhaust 26.3 26.5 mm
Width 0.5 1.0 mm
Valve spring free length: Inner 35.5 mm 33.6 mm
Outer 40.5 mm 38.6 mm
Valve seat cutting angle 32 degrees, 45 degrees, 60 degrees
Hope it helps.. Ken
Aug 18, 2014 | kawasaki ZZR 1100 Motorcycles
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
Can 215/65/16 tires on a 1999 Caravan be swapped for 205/60/16 tires?
Yes, you'll be o.k. They don't recommend anything over 3% difference, and your at about 1.8%. Speedo will read 61 mph when actually doing 60 mph. Have a look.
Stock Tire - 215/60R16 >Search Tires Tire 1 - 205/60R16 >Search Tires Section Width: 8.46 in 215 mm Section Width: 8.07 in 205 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 5.5 - 8.5 in Rim Width Range: 5.5 - 7.5 in Overall Diameter: 26.15 in 664.21 mm Overall Diameter: 25.68 in 652.27 mm Sidewall Height: 5.07 in 128.77 mm Sidewall Height: 4.84 in 122.93 mm Radius: 13.07 in 331.97 mm Radius: 12.84 in 326.13 mm Circumference: 82.15 in 2086.6 mm Circumference: 80.67 in 2049.0 mm Revs per Mile: 795.4 Revs per Mile: 809.9 Actual Speed: 60 mph 100 km/h Speedometer1: 61.0 mph 101. km/h Speedometer Difference: - Speedometer Difference: 1.822% too fast Diameter Difference: - Diameter Difference: 1.8%
Nov 07, 2010 | 1999 Dodge Caravan
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
2003 sierra rear brake rotors
there is many kind of brake system of ur truck here i will send u everything about the brake and i hope its help
Rear Brakes JC3
Rotor Discard Thickness* 18.50 mm/0.728 in Rotor Minimum Allowable Thickness After Refinish 19.0 mm/0.748 in Rotor Thickness (new) 20.0 mm/0.787 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JC4
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring1 .50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH2
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH6
Rotor Discard Thickness* 27.50 mm/1.082 in Rotor Minimum Allowable Thickness After Refinish 28.0 mm/1.102 in Rotor Thickness (new) 29.0 mm/1.141 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH7
Rotor Discard Thickness* 28.5 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
* All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this Specification. After refinishing the rotor, replace any rotor that does not meet the minimum or discard thickness specifications.
Mar 15, 2009 | 2003 GMC Sierra 2500HD
194 people viewed this question
k24674
jasbo
jasbo
