How to reset waste pad counter fo brother dcp-j125
SpideRaY
  • 687 Answers
SOURCE: DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
Posted on Sep 23, 2009
SOURCE: waste ink pad counter reset software.
Dear Sir,
My Epson R30 Photo Printer has a problem from Waste Inkpad Full massage and it's not working. I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have R390 model so, please help me to find right software to reset my printer. Thank you.
mallajanak@yahoo.com
Posted on Jan 12, 2010
SOURCE: how do i reset waste
how to resette my epson t13
Posted on Sep 28, 2010
komguy
  • 2306 Answers
SOURCE: brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Posted on Jul 30, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: how reset drum page counter brother dcp-7040
This works for my DCP-7020, so it may work on the 7040.
If your drum is still good - take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset.
Posted on Oct 20, 2009
How do i fix unable to initial 4f error
The most common cause of this will be a full waste ink chamber and purge counter.
There are lots of pages and u-tube videos to deal with this or just junk the machine and buy a new one as they are cheap enough
How to Clear the Unable to Print Message from the Brother Printer Display
May 04, 2015 | Brother DCP-J125 Inkjet Multifunction...
What to do if it always appear in the monitor of the printer that ink absorber is near full?
Not only the absorber must be cleaned, also the counter must be reset. I know there is a program for older Epson printers to reset the counter. I found a reset procedure for a brother printer here:
How to Reset Purge Counter on Brother DCP J315W Printer
Perhaps you can fine one for yours?
Feb 21, 2015 | Brother DCP-J125
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
How to solve the problem of see troubleshooting and routine maintence chapter in users guide in .it unable 4f in dcp-j140w wifi brother printer
A print unable message in a Brother inkjet usually means the waste ink chamber is full. This can be fixed by removing the waste bottle, cleaning and drying the pads inside, then reassembling the machine and resetting the purge counter. Most of the instructions for this can be found on u-tube. Please note it is a messy job and many folk just replace the machine.
Dec 03, 2014 | Brother DCP-J140W
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem http://forum.testcopy.net/threads/how-to-reset-toner-cartridge-reset-counter-for-brother-mfc-7360-printer.1915/ Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
What is the mean of ink absorber full
This is when your printer estimates that the waste ink tank in the bottom of your printer is full. If does this by keeping track of the amount of prints and cleans it has performed. In most instances you will be able to do many more prints before the tank is physically full and you can reset the counter with a simple procedure.
We have written an article and produced a short video showing how to reset the counter here. It is pretty simple and only takes a few minutes.
Sep 14, 2012 | Brother DCP-J125 Inkjet Multifunction...
Want the reset info for g46 unable to clean .dcp-330c .and would it be better to clean the waste pad as well?cheers.
Cleaning won't help as it's a counter that sets the error. It's a sealed plastic box that needs to be replaced and then reset thru service mode.Brother only gives the reset codes to authorized service centers.
Nov 27, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother dcp-150c Clean Unable 46
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
3,591 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
