Question about D-Link Tmobile Hotspot Tmg5240 Wireless Wifi Router
If i unplug my router from the modem and computer for a couple days do i have to set it up again when i hook it back up?
    Novelist:
  • 107 Answers
No. All settings should have been saved on the router already.
Posted on Mar 28, 2011
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
Linksys wireless g wrt54g router connectivity drop: our linksys wireless router disconnects about every day. We are forced to unplug the router, wait 30 seconds, and then reconnect, which brings the...
Couple actually... 1. See if you can reset the router once and set it up once again. 2. Check if you can upgrade the firmware of the router. 3. To ensure this is not a wireless issue, go wired and check if the issue continues4. Also connect to the modem directly , bypassing the router to make sure its not the modem thats actually causing the trouble.
Sep 26, 2011 | Linksys Wireless-G WRT54G Router
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
Router worked fine for a couple of years. Today, an update to Internet Explorer was installing and the baby unplugged the computer. Now the internet works when the cable modem is connected directly to...
Keep the baby away from your equipment ... it is dangerous for the baby to be pulling on wires ...
Turn everything off ... everything ... unplug your router ... at the rear, find the small hole ... insert a paperclip into the hole ... depress and hold the small button inside for 30 or more seconds. Plug in the modem ... wait for it to settle down. Plug in the router power ... press the button again with the power on. Connect the uplink (wire from the router to the modem) ... let things settle down again ... plug in other network wires ... wait ... turn on your computer(s) you will now have a router that is back in new condition with factory settings ... if not ... replace the router, there is a fault in the device.
Thanks for using FixYa.com
Oct 04, 2010 | Linksys Wireless-G WRT54GS Router...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
I have a Linksys wired router, which I have had for years and everything worked fine until a couple of days ago when I was no longer able to connect to the internet. I disconnected the router and connected...
Do this with your network setup. Power down your DSL/Cable modem first by unplugging the power. Power down the router next by unplugging the power. Power off your computer also. Now , power up the dsl/cable modem and let it resync with the ISP ...all lights green and showing activity. Next power up the Linksys router and then do a factor restore reset by pushing in the reset and holding it for a count of 5 (the front lights will go red then flash) let go of the reset as your linksys router is all set to default setttings from the factory. Now power up your computer and try the internet after it boots up. Should hook to the internet with no problems now. Now access your router menu by typing http://192.168.1.1 and hit enter. The router log in menu should now display. just click on the password tab and enter admin the default password and then change your password in the router to something hard to remember and WRITE IT DOWN! There is also great help from linksys web site on networking your home. Good luck,
Nov 10, 2009 | Computers & Internet
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
When we hook the wireless router to the modem and computer, we cannot access the internet. AS soon as we unplug it and put the computer and modem back the way it was, we can get back on the internet. How...
Log into the router so you can see the settings. Somewhere under WAN settings there should be something for you to "clone MAC address" click on that so the router clones the MAC address from the computer and this should work.
Sep 10, 2008 | Belkin Computers & Internet
Trying to hook up the internet
Your internet connection should plug into your modem, and the modem should plug into your router. Plug any computers you use directly into the router. If it's a wireless router, it's just a matter of going into the Wii and entering the settings for your wireless router.
Does this help?
Jan 26, 2008 | Nintendo Wii Console
D-Link Tmobile Hotspot Tmg5240 Wireless Wifi Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
