Question about Samsung PS42P2S 42 in. Plasma Television
I want to program the digital channels onto numbers on the remote.
    President:
  • 662 Answers
The remote will have a DASH or DOT key to let you enter the digital channel numbers directly,
as in: for digital channel 53.2, you'd enter "5" "3" DASH "2"
To program digital channels into a FAVORITEs list, you'd have to provide the Mfr/model
of the remote control itself...
Posted on Mar 28, 2011
2 Suggested Answers
  • 8457 Answers
SOURCE: Three months ago I purchased a Digital Lifestyles
The remote have the problems,it the original remote,it doesn't require programming,it automatically work,when u pushes the numbers.Go back to the place,where u bought it.Just ask for a new remote for the replacement.
Posted on Nov 30, 2010
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
How do you program a Dish Network Remote to control a DirecTV receiver?
  • 1 Turn on the electronic device for which you'll be using your remote control. You will have to do this manually by pressing the "On/Off" button on the device.
  • 2 Locate either the "Code Search" or "Setup" button on your remote control. Which one you have will depend on the remote control.
  • 3 Hold that button for anywhere between five and 10 seconds. The light on your remote should then turn on. Depending on your remote, the light will either blink or remain on after you release the button.
  • 4 Press the corresponding button on your remote for your device that you are programming. In other words, if you want to program your remote to your television, you would press the "TV" button.
  • 5 Use the numbers on your remote to enter the three- or four-digit code for that particular device. The codes for your remote control will be found in the manual. Don't worry if you have lost the manual. You can find codes for practically every remote control on the market on the Internet. Visit the website of the manufacturer of the electronic device (TV, DVD player, among others) or log onto the "Universal Remote Control Codes" website. Once you have entered the code using the remote, you should notice that the light on your remote has turned off.
  • 6 Point your remote towards the device and attempt to turn the device off. If you can do so, you have programmed your remote correctly.
Programming Without Remote Control Codes
  • 1 Repeat Steps 1 through 4 found in Section 1.
  • 2 Begin pressing the "Up" channel button found on your remote. You will probably have to do this a few hundred times (or anywhere between five and 10 minutes). Once the channel changes, your remote will be programmed. Turn the device on and off using your remote to finish programming.
  • 3 Use the "Power" button if the channel button did not program your remote control. Again, you will probably have to press the "Power" button a few hundred times. Once the device that you are programming your remote to has turned off, you will know that you have programmed the remote control correctly.
Sep 14, 2011 | Televison & Video
Three months ago I purchased a Digital Lifestyles television in Weslaco, TX. I still am not able to use the remote to switch channels automatically, I have to press my channel button to go all the way...
Nov 30, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
Can i access my digital channels on cabel without a box? I dont want to have to type in sub numbers, can my remote be programed for that?
Local digital channels should be available from the cable TV line from the wall. Your TV has to have a digital tuner. You can do a channel set-up scan with the TV. Then do channel up and down or channel # access to get to desired channel.
Apr 14, 2010 | Televison & Video
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
My SONY TV remote control doesn't do what it should
problem due to dry soldering remote microprocecer
May 21, 2007 | Sony RM-Y135 Remote Control
Samsung PS42P2S 42 in. Plasma Television Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
