My sata hard hard drive is not detected in linux
Sata -ii western digital 160gb hard drive
  • 22 Answers
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Posted on Aug 19, 2009
  • 37 Answers
Hi
Let me know when it is not detecting while installing the Linux/add a new HDD in the linux system, if its happening during the installation then download the sata driver from the linux site which Linux you are installing then try it
T.Boopathy
Posted on Aug 09, 2008
How to fix my wd scorpio and can use it again?
Open Control Panel ' select System ' select system devices ' look for yellow triangle on unknown device or under storage device / hard drives. Select detect / add new device with drive connected.
Feb 12, 2015 | Western Digital WD Scorpio Blue WD2500BEVT...
WD1600BEVT-60ZCT0 Not detecting
OK then. I assume the problem was solved by the procedure described in the last comment box - re-install USB disk drivers.
27.April.2014
Apr 15, 2014 | Western Digital WD1600BEVT-60ZCT0 - 160GB...
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
Firmware for wd
Go to Western Digital because they make the drive and write the firmware.
Mar 19, 2012 | Western Digital 250 GB Scorpio Blue SATA...
Hardisk not detected
- Check hard drive connection (SATA cable).
- Check Bios Setup (hard drive configuration - SATA drive should be enabled)
May 16, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
789 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
