Question about Biostar TPower I45 LGA 775 Intel P45 ATX Intel Motherboard
Hi ihave a memory problem.My Biostar TPOWER I45 ia not working in Dual-Channel mode. We have tested with about 5 different memory manufacters but no Dual-Channel mode It reads all memory that I put in the motherboard. Is there anything to be done or what should I do?
  • 1 more comment
  • Jukka Kukkonen Mar 28, 2011
    Yes I know that order into whitch slots i should put the memory stics,1 and 3 or 2 and 4 but CPU-Z is showing me everytime that the mobo is running in single mode?????
    Can you tell me what is the difference in performance without having Dual-Channel working as it should,compared to my present situation meening NO DUAL-CHANNEL working??
    No, I have not put ever (yet) my sticks in slot 1 and 3.Are you sure that if I try that ,it doesnt brake
    anything in mobo?
  • 902 Answers
Are you putting the sticks in slot 1 and slot 3
Posted on Mar 28, 2011
Does the Biostar G41D3 Intel G41 Socket 775 Motherboard except a single 4gb memory module
Yes, with one you will not run in dual channel mode but, depending on what you are doing,may not notice any difference.
May 09, 2012 | Biostar G41D3 Intel G41 Socket 775...
I have a tpower i45 and when i turn the computer on it comes one for a fraction of a second then a red light comes on the motherboard and thats it i have had computer for 2 years now never had a problem...
Hello
If you have more then one memory stick,take one out at a time and try to boot up.
If pc boots up then you know you have a bad memory stick.
More then likely this is the problem.
Next remove each pci component one at a time. Vid card, sound card, ethernet card,see if pc will boot up.If it does then you know its a card.
Last if none of this works then it may be your processor.
Aug 05, 2011 | Biostar TPower I45 Motherboard
Dual channel means two channels of memory. there are two configurations you can use. you can use single channel method which has twoo ram sticks running on one channel or you can have a seperate channel for each ram stick. Dual channel is said to be the better way to run it because it increases speed of the ram. Now assuming you have 4 slots for ram. to use dual channel you have to run 2 sticks of the same value (MB) right next to each other. You cannot run 2 sticks of different values in dual channel mode. In the case that you do the sticks would pair together on a single channel. Hope this helps you better understand.
Mar 28, 2011 | Biostar TPower I45 LGA 775 Intel P45 ATX...
Acer aspire m5100, AMD Athlon 64bit x2 dual core processor 5000+ 2.60Ghz. Win Vista Business 64bit. When i upgrade and put more than 3GB of ram into the machine, it turns off the lan and my display driver...
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Will P4M80-M4 motherboard support dual channel memory?
This is an older board. The VIA chipset pre-dates dual channel memory support. If your board is working fine, this should not be a concern.
Jan 08, 2010 | Biostar P4M80-M4 Motherboard
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Windows loads on every other boot.
Let's try running a memory test program. http://memtest.org/
Scroll down till you see the three screen shots. Just under them pick you're choice of bootable media to test you're memory.
Download - Pre-Compiled Bootable ISO (.zip)
or
Download - Pre-Compiled package for Floppy (DOS - Win)
Luck!
Mike
May 15, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Biostar TPower I45 LGA 775 Intel P45 ATX Intel Motherboard Logo
71 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
