Question about Panasonic Televison & Video
The DVD player tried to read the DVD and stopped. It said H07 and then display reads STOP
  • Panasonic Master
  • 508 Answers
Many Panasonic DVD units use a traverse unit (spindle motor/laser assembly) - and the H07 error indicates a failure of this component block (the spindle motor is the part of the unit which fails first).
This part is not repairable, it can only be replaced by a qualified authorised Panasonic technician - then it must be aligned and the firmware updated/configured to the player. The problem with this is the costs involved; a new spindle motor/laser unit (through Panasonic directly) would cost around $200 trade plus the labour/fitting/alignment - it could be a further $200 - making it uneconomical to fix - since this would be about the price of a new player.
However, you can submit the unit to a service centre, for a quote on the likely part/labour cost(s), then make a decision afterwards - whether to go ahead with the repair or cut your losses and buy a new player.
Blu-Ray players (with DVD playback support) are becoming cheaper to buy nowadays while repairs to DVD players become more expensive. It's up to you.
Posted on Mar 28, 2011
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
Dvd player not working
the dvd i have it blows the fuse what could be the problem?
Feb 03, 2009 | Panasonic DVD-RV32 DVD Player
H07?
Replace Spindle motor.
Sep 14, 2007 | Panasonic DVD-S35 DVD Player
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Televison & Video Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
