HL-2140 is offline how to take online? OS X Problem started with new computer.
  • Steven Dalos Mar 28, 2011
    HL-2140 is printing again!
  • 794 Answers
Hi mrgaijinsan,
Here's a PDF document with the instruction for new firmware which now help you address the issue of getting the offline message and will allow you to print. If you also did an upgrade to Macintosh OS X 10.5.5 this is also the fix. Please click this link for steps in updating the printer's firmware, this is applicable for HL-2140 as well.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 28, 2011
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
I have brother Printer HL 2140 . This printer become offline automatically after some time & does not print. how we can solve the problem.
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
Mar 08, 2011 | Brother HL 2140 Laser Printer
My brother 2140 laser printer keeps going offline
hold the power button for a few seconds. it worked for me :)
Feb 08, 2011 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
Will the Brother HL-2140 laser printer run on Windows ME? If so, where can I get the proper driver?
brother doesn't supply drivers for WinME for this printer. also take note that WinME is not supported OS for most of new hardware and software.
Feb 26, 2009 | Brother HL 2140 Laser Printer
I don't have a disk - can I download driver for HL-2140?
Hi!
Please use this link to download the drivers of your printer. First select the OS you are using(vista,xp or any other). Then select the language and then download the drivers for your printer.
Brother HL 2140 printer drivers
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | Brother HL 2140 Laser Printer
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Computer (windows 98) won't read driver/disc install of Brother HL-2140Says OS not compatible - but online research says otherwise
Windows 98 is not compatible with this unit. I could not find info that it was compatible. I went as far to contact brother directly and they gave me the same info, it is not compatible. There are rarely any new units that you can find that are compatible with windows 98. My suggestion would be to upgrade to windows xp or vista. Tiger Direct has great prices for windows OEM versions, service pack 2 is going for 90 bucks. They are a reputable store/online warehouse. They always deliver on time and i never had damages. Let me know if you need more info
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=306&srkey=windows
Dec 11, 2008 | Brother HL 2140 Laser Printer
Need a printer driver for OS Windows 98 SE for Brother HL-2140?
Nov 12, 2008 | Brother HL 2140 Laser Printer
k24674
jasbo
jasbo
