I need a 2m coaxial extension. Where can I get this?
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Hello
Coaxial extension cables can be bought from most of the electronic spare part shops in your town. Up to 5 meters are available. When choose a lenghty one, select a super quality type. i recomends 'Monster". Eventhough it is colstly, it has its qualities. OK.
Posted on Mar 28, 2011
Yamaha np 32 some keys faint in response
This is normally caused by dirty or worn contacts.
Simply open up the keyboard and replace the contact rubbers when the sensitivity has been lost.
There are 4 different rubber contacts depending on which notes are not working
WJ231101 RUBBER CONTACT 16N-2M OCT 2M-55
WJ231200 RUBBER CONTACT 16N-2M OCT 2M-45
WJ231301 RUBBER CONTACT 16N-2M 76H 2M-45
WJ231401 RUBBER CONTACT 16N-2M 76L 2M-55
Nov 12, 2016 | Yamaha Music
I CAN LOST MY PHOTOS ON PHONE MEMORY. HOW TO GET MY FILES BACK
try to goto settings and look for your files and they might be there , good luck just open files and scroll down to photos and open it up if you did not delete them they will be there
Mar 18, 2014 | DURAGADGET 3.5mm plated Extension Cable -...
Connect ps3 just sound to surround sound
PS3 has an "optical out" port. Use an optical coaxial cable (something like this one XO Digital Optical Cable 2m 2 Metre Premium Install Series suitable for... ) to connect this to an optical in port on your surround sound receiver/amplifier.
Go into the sound settings on the PS3 and set it to output dolby digital 5.1 from the optical connection.
Switch your surround amplifier to the appropriate source.
Feb 03, 2014 | Video Game Consoles & Games
How to unlocked Nokia C2-01
Use unlock code to unlock your Nokia C2-01. Get the code from the site Wickedunlock.com ,and unlock it using unlocking instructions which is given in the site itself.
Aug 02, 2013 | DURAGADGET 3.5mm plated Extension Cable -...
Replace antenna
Remove old Antenna
  1. Activate the antenna switch to the up position.
  2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Gain access to the underside of the area of the trunk where the antenna is located.
  4. Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Remove the mast.
  6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Remove the ground lead from the panel.
  8. Pull out the antenna coaxial cable.
  9. Unplug the coaxial from the extension coaxial cable.
  10. Remove the original antenna coaxial cable. Note the route the cable follows.
Install new Antenna
  1. Inspect the fender area where the antenna mast will be mounted for rust.
  2. Clean the area before installing the new antenna.
  3. Plug the new antenna coaxial cable to the extension coaxial cable.
  4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  5. Connect the power lead of the antenna to the power antenna lead on the radio.
  6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  11. Stop the motor after the cable goes into the housing 12 to 25 inches.
  12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  13. Replace the retainer nut to the base of the antenna mast and secure tightly.
  14. Replace the panel that covers the antenna mount area.
Oct 16, 2009 | 1996 Honda Accord
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Jul 26, 2009 | Foxconn Computers & Internet
Antenna mast broken
    Give these instructions a shot. Might be too generic but might be enough to get you going. Removing Original Antenna
  1. Step 1 Activate the antenna switch to the up position.
  2. Step 2 Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Step 3 Gain access to the underside of the area where the antenna is located.
  4. Step 4 Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Step 5 Remove the mast.
  6. Step 6 Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Step 7 Remove the ground lead from the panel.
  8. Step 8 Pull out the antenna coaxial cable.
  9. Step 9 Unplug the coaxial from the extension coaxial cable.
  10. Step 10 Remove the original antenna coaxial cable. Note the route the cable follows.
    Installing the New Power Antenna
  11. Step 1 Inspect the fender area where the antenna mast will be mounted for rust.
  12. Step 2 Clean the area before installing the new antenna.
  13. Step 3 Plug the new antenna coaxial cable to the extension coaxial cable. (On some General Motors and Ford cars you may need an adapter to mate the 2 cables together. Car audio retail stores sell such an adapter.)
  14. Step 4 Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  15. Step 5 Connect the power lead of the antenna to the power antenna lead on the radio.
  16. Step 6 Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  17. Step 7 Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  18. Step 8 Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  19. Step 9 Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  20. Step 10 Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  21. Step 11 Stop the motor after the cable goes into the housing 12 to 25 inches.
  22. Step 12 Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  23. Step 13 Replace the retainer nut to the base of the antenna mast and secure tightly.
  24. Step 14 Replace the panel that covers the antenna mount area.
May 13, 2009 | 1993 Chevrolet Corvette
Upgrade to window vista & can the processor be upgrade
Hello Rizmum,
Yes you can change the processor,Kindly look for following processors if they are available in the market
Intel Pentium -M (Dothan) 725 1.6GHz 2M/400MHz FSB (Pentium M 725 (1.6G 2M 400FSB)
INTEL PENTIUM M 1.7G 2M 400FSB uFCPGA2 SL7EP B-1 STEPPING (Pentium M 735 (1.7G 2M 400FSB)
ntel Pentium -M (Dothan) 745 1.8GHz 2M/400MHz FSB (Pentium M 745 (1.8G 2M 400FSB).
Let me know if you require any further information on this.
Thank you,
Regards
Hemanth
Apr 13, 2009 | Computers & Internet
12+2m=20-2m
12 + 2m = 20 - 2m
2m + 2m = 20 - 12
4m = 8
m = 8/4
m=2
Mar 06, 2009 | SoftMath Algebrator - Algebra Homework...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
