Question about Garden
Can't seem to find a place that sells the 3 burner replacement. its 3 burners but 1 piece any help would be great
    President:
  • 1,851 Answers
Please be more descriptive. What brand lawn mower uses a 3 burner unit? Is it s stove or a lawnmower?
Posted on Mar 28, 2011
I have a bernzomatic 94499 patio heater does anyone know where I can find an owners manual? The pilot will light but not the burner? There is a brass fitting towards the back that seems to be the burner...
You need to replace that brass piece . Its a thermocouple. Bernzomatic does not sell a replacement thermocouple, however I had success using Mr. Heater 12.5" replacement thermocouple. You can buy it from Ace hardware. Its also sold on Amazon.
http://www.amazon.com/Mr-Heater-12-5-Thermocouple-Heaters/dp/B000BP7LJ2/ref=sr_1_1?ie=UTF8&qid=1325746531&sr=8-1
To remove the nut on the old thermocouple I use a 13/32" socket. I think a 10mm would work also. Must be a deepwell socket. The new Mr. Heater nut takes a 7/16" socket. The old thermocouple runs to a black plastic piece with soldered on connectors. I removed this piece entirely. The electric igniter's ground wire runs to one of the bolts, so that must be put back after the piece has been removed. I did make the effort put the white cloth cover over the new thermocouple. I took it off the old one. I barely fits over the nut, and must be worked on like a Chinese finger trap but it will go. Good luck.
Sep 07, 2011 | RTO Bernzomatic Brushed Nickel Patio...
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
I would like to upgrade one of my burner grates for a GE "Gas Slide-in Range (Model #JGSP20). The individual burner grates are 8 5/8" square and 7/8" high. I would like to locate one...
Hi!!
A new OEM grate for your unit will cost about $62.00 + S&H at this place http://www.repairclinic.com/PartDetail/Grate-or-Griddle/258336
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 08, 2011 | Microwave Ovens
All 3 Burmers won't stay lit
I contacted the company. Phone number 800-694-0013. You can order replacement parts thru them but they cannot take credit cards by phone you have to mail in the payment and they will Fed-Ex the part when they receive it. The lady I spoke with was very nice and helpful, she stated these grills are made for Meijer's pretty much exclusively and they are made in China and that if you can locate their website it is all in Chinese. She also stated the distributor has opted not to sell the replacement parts for these in the store.
May 16, 2009 | Brinkmann 810-2300-B Grill
Gas oven not working pilot light is out
1 of 2 things will normally happen and most of the time both things will break. You have two main componets that will wear out 1)your igniter 2)the gas burner tube. Usually what will happen is the gas burner tube allows gas to come out of 3 very small holes-over time and with help from grease, the 3 small holes will turn into a large hole and will allow too much gas to come out and it will destroy your igniter also. Luckly RepairClinic.com sells both pieces in a kit. You can check you igniter with multimeter for continuity (if it is broke-safety kicks in and wont allow gas to work).
May 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Sep 11, 2007 | Jenn-Air JGC8536 Gas Cooktop
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
