Question about RCA DRC275 DVD Player
My rca model drc-257n won't turn on. it is plugged into a good socket. remote won't turn it on ether
  • RCA Master
  • 508 Answers
Faulty switchmode power supply in the unit, due to several failed components including electrolytic capacitors which may have leaked. Look for bulging or leaky caps, and burn-marks on the PCB, around IC regulators (these can be 3 or 5 pin devices and they stand upright on the board) - chances are 1 or more of these ICs has short-circuited as well as the caps.
You can take the player to a service repair centre for a quote on the likely cost(s) involved to restore this unit to working order, as well as a second opinion, then you can make a positive decision afterwards as to whether it will be economical to fix or not. Up to you. I warn you that it could be expensive; equal to or more than the price of a new unit.
New players (even Blu-Ray with DVD playback support) are becoming cheaper to buy nowadays, while repairs to this and similar model DVD players become more expensive, often with suitable replacement parts not being available. If you truly love this little player, and you want it working, consider the abovementioned workshop quote suggestion first.
Posted on Mar 28, 2011
Remote:Remote control setup code for RCA model DRC 6000 N
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
May 07, 2015 | RCA Televison & Video
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
We have a RCA VCR Model VR622HF Manf. 9-18-98 that suddenly won't turn on manually OR with remote. I am an experienced Electronic Tech with 43 years @ ATT. I measured the resistance at the AC Plug and read...
If front display lit up when vcr plugged in that means power supply is working and issue is in system control section, and if front display remains dark while vcr plugged in wall socket then power supply is defective.
As you know its an old model vcr so I do not think spare parts would be available any more, I found good option for you to fix this vcr.
Click eBay.com link to get same vcr in working order for $40 that can be used to obtain either power supply or any other board/ parts to repair your vcr.
Hope these info will help you.
Thanks.
Dec 14, 2010 | RCA VR622HF VHS VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Still can't find a code for Electron LCDTV
You have joined the ranks of those who have several 'universal' remotes. They aren't. They are, at best, multidevice or multibrand remotes and even the 'learning' remotes don't learn from some originals. The use of the word 'universal' is a fraudulent nomenclature.
In looking at the product description, I noticed this:
"The DRC450 remote control is designed specifically to work with all Motorola and General Instrument Digital Cable Terminals."
It was then never designed to handle any updating.
You might try to obtain newer codes from the Motorola site for your model:
Motorola DRC-450
I didn't see any provisions for updating the code set via computer so it will likely never do what you want.
Jul 06, 2009 | Logitech Harmony 550 Remote Control
User Guide for RCA DVD RCR 110D A1
The manual for this remote control is embedded in the operating manual of the DVD Player DRC 220.
icon_arrow_download.gif RCR 110D A1.pdf
Apr 16, 2009 | RCA (DVDCP33) Media
Language Selection for RCA DRC 220N
try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
May 04, 2008 | RCA DRC220N DVD Player
RCA DRC275 DVD Player Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
