The incorrect code was put into sun safe mode ES-M020 and now we cannot open the safe
2 Suggested Answers
SOURCE: Incorrect code for radio. Where can i get a new code?
If you tell me the model number and make of radio i may have the right code
contact me at 07821810506
Posted on Apr 09, 2009
How do I get out of safe mode on my car radio?
Gotta leave it powered up for a period of time and wait, can be I believe an hour or so if incorrect code has been entered
Jul 27, 2014 | 2008 Seat Ibiza 1.2
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
When i turn on computer the monitor shows the windows screen or sign in page then go es blank then does the same thing if you power off manual then restart its like it goes to sleep but theprogram is...
this sounds like the screen may be trying to display a resolution higher than the screen can support. Try booting up in safe mode and seeing if you can see your desktop. Also is this the only monitor connected to your PC or is this a dual screen setup? If it is dual screen you may not have your second montor turned on.
Dec 03, 2010 | HP 2159M Monitor
How to exit Radio Safe mode on my passat
Hi
Wiih most radio units....If you have the proper code and have NOT tried more than 15 times to enter an incorrect code....you should be ok.
Turn OFF ignition switch and remove the key. Switch OFF interior lights. Switch ON Radio unit and SAFE will appear.
Leave everything alone for a period of ONE HOUR. During this time NO power (no matter how small) should be drawn from the battery. This is why the interior lights MUST NOT come ON when the door is opened. Trunk should also remain closed. In the event of any power been drawn from the battery in this time...You must start all over again.
Radio should after this time return to standard mode...Usually 4 flashing bars. Then enter your code. Dont forget to lock in the code and all should be fine
All the best with it
John
Nov 26, 2009 | 1998 Volkswagen Passat
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
Cd player es safe mode
Safe mode means, That to make the radio work need the Security code entered , Normally is in the Owner's manual or a separate ID card.
Supplied for the Dealer ship.
Maybe The BATTERY was Disconnected or the power to the radio was interupted.
Ok.. I hope this help on your question
Thank you for use fixya..
Apr 22, 2009 | 1999 Volkswagen Passat
Stuck in safe mode
There is a botton on the remote (Lock) that puts in safe mode and off.
Dec 03, 2008 | GoVideo VR3845 DVD Recorder/VCR
My samsung x05 wont open up windows when i put in my password
Can you log on in safe mode (hold F8 on bootup and select safe mode without networking)? Are you running Windows XP? You could try using system restore to go back to a time before the problem started. Is your hard drive volume name longer than 11 characters?
Dec 06, 2007 | Samsung X05 Notebook
93 people viewed this question
k24674
jasbo
jasbo
