Question about Laguna Pressure - Flo Uvc Filter: Pf 2100
I could not get the lid on the PF2100, I tried the solution listed on this site. I was able to get it on with the rubber gasket by putting the lid upside down the putting the rubber gasket on the lid. Then I slid the bottom on to the lid. I was able to close the metal clamp. My problem is the filter leaks around he clamp. It is a few drip leaks. I have had this filter 3 years and this is the first time it leaked. Each year its always hard to get the lid on.
  • Alan D G Apr 10, 2011
    I tried it but I could not get the lid on my wife and I use all fours to get even pressure.
    The only way I could get it on is doing the process upside down and forceing it to close but I get a few little drip leaks, I am wondering if the rubber gasket expanded somehow. When I put it in it fits but not tightly. This is the first year out of 3 that I could not get the lid on. this is also the first year I did not let the filter run all winter.
  • 56 Answers
It sounds like the seal simply didn't seat properly. I recommend placing the rubber seal along the rim of the bottom canister and lowering the lid onto it vertically as uneven pressure can cause the seal to shift out of position. Make sure to check the rubber seal for pinched or hard spots and cracks as these will cause your leaking issue. It can take a few tries to get everything to sit just right. I always dread my bi-annual filter servicing for the same reason but with practice it becomes easier to get them to seat on the first shot. If you are running this filter on a freshwater pond with more than 800 gallons a very small amount of mineral oil (less than an 1/4 ounce) can be rubbed onto the seal to ease seating.
Posted on Mar 28, 2011
  • Peter Freese Apr 10, 2011
    I am sorry to hear your still having trouble. Was the filter left in place when it wasn't running? Cold weather and no water circulation can cause ice to form inside and push things out of place with an amazing amount of force. If this is the case the case may be stretched out of shape very slightly. The gasket shouldn't expand but does have the capacity to shrink unevenly. You may wish to check with your local retailer to see if they offer a replacement seal as I am having trouble locating one online for you (If I do find one I will post the link here).
Intermittent fault top loader
please check the door switch or leak the door switch for test and check the capacitor motor
Feb 08, 2014 | Simpson Esprit 750 Top Load 7.5kg
Need rubber to hold lid on
http://www.marbeck.com/hamilton-beach-slow-cooker-replacement-lid-latch-band/
Feb 02, 2013 | Hamilton Beach 33162 Stay or Go Stainless...
How to change valve cover gasket on a 99 ford taurus
remove spark plugs and high tension cords/ remove the valve cover bolts using socket wrench/ use screw driver to lift up the valve cover/ clean the lid/ put a new gasket and put silicone gasket sealant on the edge of half moon rubber gasket to avoid leak/ tighten the bolts/ put the plugs and wire back...
Apr 07, 2010 | 1999 Ford Taurus
How do i remove and replace rubber seal on door of hotpoint aquarius washing machine
Remove the lid and loosen the band internally holding gasket to tub, from the top. The front come off easily once the retaining band is removed. Just reversed the process to put on the new rubber.
Dec 09, 2009 | Washing Machines
Where can I buy a rubber gasket or whole lid for Tiger PDH-B30U electric water boiler? Thanks.
try this site
http://www.veryasia.com/tiger-whole-lids-replacement-part.html
Oct 04, 2009 | Tiger PDH-B30 Electric Kettle
The rubber in front of the machine has come out so has the metal spring that goes around it
take lid off put rubber back in place and put the metal holder around the rubber with screw loose try have the clip connection to the top as this helps with tightening. tighten screw and jobs a good un
Jun 23, 2009 | GE WSXH208A Front Load Washer
Laguna Pressure - Flo Uvc Filter: Pf 2100 Logo
329 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
