Question about Electrical Supplies
Garage door only goes one third of the way down and stops. It was about to hit the car and I hit the button a couple of times so that could have thrown it off. Any thoughts???? Thanks so much
  • 10,865 Answers
Hello sue... That activity must have thrown the door out of adjustment.. On the motor unit there are high limit and a low limit adjusting screws. The low limit screw needs to be adjusted to move the door down until it closes properly. Just adjust it 1/4 turn at a time and then test it to see where the door is at. Joe
Posted on Mar 28, 2011
Garage door goes down and stops, hit the button again and the garage door still wants to go down. Bends the track.
Release opener from door, by pulling down on the red rope. See if you can manually raise and lower door. If not you need to determine where the problem is. If the door is heavy when lifting call a garage door company. The torsion springs are very dangerous
Jan 07, 2018 | Building Materials
My garage door goes down and as soon as it hits the groung it goes back up and light flashes on and odf
You need to reset the down button so the door stops just about when it gets to the bottom. You have it set past that point so consequently it sees that it is hitting something and reverses itself.
Sep 21, 2017 | Building Materials
How do I get my garage door to open?
broken springs...door to heavy for motor to lift call a pro
Oct 11, 2014 | Building Materials
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
Liftmaster Professional 1/2 horse model # 41A5483 installed in 02 Learn light flashes 4 times. When openers are hit in cars (2 Chrysler vans use built in Homelink Systems built into sun visors, one car...
check the settings on the unit itself sometimes if you have it set up to come down too rapidly it will cause it stop and go back up because it thinks its hit something.
Apr 10, 2011 | liftmaster Garage Door 1/2 Hp
I have an access master door opener..it goes up about 6 inches and stops, hit switch again, goes down, hit switch again goes up about two feet, hit switch again goes down, third time switch nothing until...
Door sensors have nothing to do with door opening. Only closing. It sounds like you have a bad gear in the motor unit. Remove the cover and it will be obvious if the gear is bad.
Feb 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door goes up just past eye and stops. If I hold button down will go up all the way. Must hold button down for down position also or stops every couple feet.
Check your door springs and also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. You need to check your door sensors also. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit if necessary.
Mar 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open or close garage door; inside button flashes
What has happened is that you electric eyes are blocked or have gone out. The eyes are at the garage door about a foot of the ground on both sides. There should be a red or green light on one of them. If not some thing is blocking the beam that goes across the door. It is a safety beam so kids can nt get hurt when the door is coming down. If the beam is broke the door will go back up.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
