Question about Dryers
I have a Maytag MDE9700 dryer bought in the US and now in Australia we have wired it up through a step down transformer and are getting the FE error code, looking through the instruction information it's saying invalid power frequency sense circuit. I realize the difference between 50 and 60 Hz, but in this case we are talking about an electric motor and heating elements, that should still run. Is there a way of bypassing the sensory circuit, realizing the motor may run slower.
  • 1 more comment
  • Tony Adams Mar 28, 2011
    Thank you very much for the information, I have it wired with two hot 120 V wires to the two outer terminals and the neutral in the middle from an 8000 W step down transformer, from 240 V to 110 V. The internal light works all the lights come on it all looks like it's going to work, and then it gives the FE error code. Somewhere it's sensing we are running on 50 Hz not 60 Hz the handbook says the error code means invalid power frequency. I think it I have the wiring right, that's all it can be but I'm not sure how to get around that problem.
    Thanks again, I gave it a try but it plays the same as music with the FE code still flashing.
  • Dryers Master
  • 3,740 Answers
I have the service manual for this dryer 16025911 (manual number) and I read everywhere I could to see if there was a way to bypass the frequency sensor. It is part of the main board unfortunately and it is not adjustable or bypassable.
Deep into the manual on page 41 of 58 there is the statement that I can not copy and paste but have retyped verbatim:
Maytag dryer models manfactured for operation on 60Hz AC are not designed for use on 50Hz AC electrical service and conversion of the product from 60 Hz to 50 Hz is not recommended.
I know this answer was not even close to what you wanted to hear. Possible alternative... ?? Portable but fairly large (30 amp load) portable Generator running at 3600 RPM / 60 HZ. ( I really tried to think of any economical way to help you out here but unless you can trick the 50 Hz frequency into performing at 60 Hz your dryer is not going to work.
As you said the motor and heating elements do not care 50 / 60 Hz... but the control board is the heart and the heart you have can not operate at 50 Hz.
Kelly
Posted on Mar 28, 2011
  • Dryers Master
  • 8,220 Answers
I would not be concerned about the 50 or 60 hz. I would be more concerned with the motor is 120 volt whilst the 5000 watt heating element is 240 volts. The power on dryers in the US is based on a neutral with 2 hot legs L-1 and l-2. The motor uses a circuit that is L-1 and neutral. The heater requires L1 AND L-2 I have a Maytag MDE9700 - themobilian_2075.jpgAs yall can see on this diagram they is plainly 2 hot wires Red and black and one neutral white wire. On American dryers that white and black wire runs the motor. Another circuit powers the heating element using red and black. Hope this helps ya.
  • Dan Webster
    Dan Webster Mar 28, 2011
    What yall could do is reverse the 2 hot woes and see if the machine agrees with that.
  • Dan Webster
    Wires oopz
Maytag dryer MDE9700 AYW We replaced the dryer heating element and the dryer still don't heat can anyone help me figure what parts I need
http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html 14 and 15
Jan 12, 2016 | Maytag Dryers
The heating element connects to a thermal fuse and then to a thermostat. The thermal fuse may be blown. There is no outward sign of failure http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html
14 and 15 on the diagram
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag mde9700 no power and has buzzing sound
Usually on these models if it sounds like a stuck motor sound could be the motor or the pading on the drum that peeled off and probably stuck between cabinet and drum
Jun 04, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Hi, just purchased the JS8 from the States (I'm in Australia), and power connection is, I assume, an American one. Can you please advise which converter I need to purchase so I can operate this unit in...
If you are on 220 there, just get a 220 to 110 TRANSFORMER type step down. You don't need a very big one, then you can use the supplied convertor. DO NOT use one that is intended for hair dryers type appliances.
Jan 05, 2011 | Roland Boss eBand JS-8 Audio Player JS-8
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Francis Francis X3 voltage
hello. The electrical power used in most of Japan is very similar to that of the USA. The difference is that Japan uses 100 volts as opposed to our 110. Therefore, most electrical appliances, blow dryers, etc will work equally well in Japan and in the USA.
Since you are in Australia now, use the same adapter for your expresso machine as you use for other small appliances and you should be fine.
Sep 13, 2009 | FrancisFrancis! X3 Espresso Machine
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
105 people viewed this question
Top Dryers Experts
