Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Toner low Got an error message re Toner low did'nt realise this machine needed a toner. If it does cant find from manual where a toner would go
There is no Toner with this printer.
It uses Ink Cartridges. (It may say toner as that what most people
say ink is these days) - correct me if I am wrong!
The different ink colours are seperate, so you only replace the one which is low. Print heads need to be changed after changing the ink 2-3 times but it does not say that anywhere (I think they would recommend changing it all the time but that makes this v.expensive running costs which beats the object of this printer)
Yes I do have one, so I know what I am talking about.
Just a shame as my experience has led me to believe that this drains the ink as it calibrates every time you turn it on! (Paid £400 for this when it first came in the UK)
I do not leave it on standby and ink lasts me max a month and I only use about 100 ~ 150 pages (**** really) hence why use a laser for B/W and this for every thing else.
Plus any one know where you can refill this cartridge using standard ink?
Posted on Sep 08, 2008
I have sharp ar-5316e indicator massage error ink.drum. toner
Toner indicator says that there is low toner in the machine. It is necessary to replace toner cartridge and then continue with other error messages.
Apr 29, 2017 | Sharp Office Equipment & Supplies
Tip
Toner empty,toner low,no cartridge
hello, this is a appear when replace new toner
some time machine didnt recognize toner.
press menu#1934
display ready tech
press menu &left arrow key display new cartridge enter twice.
and restart machine error message is over
on Aug 14, 2010 | Office Equipment & Supplies
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
I already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Jun 15, 2009 | Kyocera Office Equipment & Supplies
Toner low we installed new toner. then message
remove plastic cover from toner yellow or any color and install toner properly.
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
Error 7C
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
Dec 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Xerox dc12 error message 9-355 on machine cant find out what it means. anyone help
that is a magenta toner empty message.
If the toner is not empty you most likely have a bad toner dispenser.
May 01, 2008 | Office Equipment & Supplies
E020 Error message on NP6050
A E020 code is a toner amount problem in the developing ass'y. Is the copier asking for toner or was it and no toner was installed? If not the amount of toner is to low for the hopper to add enough toner in to over ride the toner sensor. Look in the developing ass'y for toner, if you only see about a 1/8' of toner you need to clean or replace the toner sensor. Then you are going to have to run in service mode " toner-s". Then rechk the amount of toner in the developer ass'y. It should be about a 1/2' or so. If not you have a problem with the toner hopper. And if that is the problem you may want to manually add toner in the developing ass'y to get the copier working again. You also have to clear the error code in service mode.
Jan 28, 2008 | Canon CLC 1120 Color Copier
MFC 7420 always say toner low after you change new toner
1. Open the front cover door.
2. Press the "Options" button.
3. Type *00 on the keypad.
This will clear the error message.
Enjoy!
Nov 20, 2007 | Office Equipment & Supplies
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
109 people viewed this question
Ben Johnson
