Question about Robotoolz Rt 5250 2XPK Electronic Self Leveling Rotary Laser Kit and Detector High Power 2 Beam
I have a robotoolz RT-5250-1 that will not self-level. I have replaced the batteries and made sure it sitting on a level surface. I have followed the instruction manual on calibration to no avail.
4 Suggested Answers
  • 2976 Answers
SOURCE: The red beam on my laser won't show outdoors?
Check for a lint ball or a small piece of debris in the lens area. The smallest piece of anything will knock the brightness down. New batteries would be the only other thing I would think of.
Posted on Jan 30, 2009
  • 174 Answers
SOURCE: where do i get a manual for my robotoolz rt 7610 5
try looking here. http://www.einet.net/review/267202-94278/Welcome_to_RoboToolz_Online.htm
Posted on Nov 05, 2009
#1 Taper
  • 1041 Answers
SOURCE: i have an rt-5250-1 self
If the directions are not real clear as you say, then you should call the manufacturer to get tech support. I will send you a link to there site and phone #.
http://www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
Good Luck!
Jim
Posted on Sep 13, 2010
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Need a RT-5250-1 Users Manual
Try freemanuals.com for your needs here
Apr 04, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Does not power on. batteries new
check batters ports see that they are clean
Jan 13, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Jan 27, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Robotoolz Rt 5250 2XPK Electronic Self Leveling Rotary Laser Kit and Detector High Power 2 Beam Logo
761 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
