Question about Toshiba Televison & Video
My Toshiba backlit DLP 60inch 1080P tv comes on and the bulb comes on but it gets nothing from the Direct TV reciever or the CD palyer. I can get the menu, the Toshiba menu. Please help.
  • Maureen Redfern Mar 28, 2011
    Will do. Thanks. Talk to you tomorrow.
    Maureen Redfern
    Alright, I unplugged the TV and plugged it back in. It's working again. What's up with my TV? Why did it go black?
    Maureen Redfern
    President:
  • 1,654 Answers
First thing I need you to try is to change the input cables around and see if you can pick up the signal that way. use an input that you haven't used before and while your at it. do a re boot on the sat reciever, I mean pull the card out and power it down, put the card in and power back up. This will take several minuts but it may just need to be re-set. Also if this does not help. Try re-booting the set, unplug overnight and let it set as long as you can, then plug it in and turn it on and see if it gets restored. This is uncommon so I don't wan't to make any guarantees yet. While your in the menu check and make sure your selecting the correct settings of for the devices, make sure some how things didn't get changed. If all else fails you may have a bad tuner board on the set, but like I said this is unusuall. Let me know tomorrow if any of these worked.
Posted on Mar 28, 2011
  • Dcramer531
    Dcramer531 Mar 28, 2011
  • Here are some quick notes on solving the usual issues like this. My or may not coincide with your issue but here is something else to try.
  • Plug in the television.
  • Change the batteries in the remote control. When the batteries are dead or low, the remote will not communicate with the TV.3
  • Secure all the cables for external devices, such as a DVD player, into the correct connections on the TV. Loose and incorrectly attached cords will keep the TV from working properly.
  • Unplug the TV and wait five seconds. Plug it back in. Many problems, such as a TV or HDMI device that is unresponsive to the control panel or remote control, resolves itself using this step.
  • Press the "Input" button on the remote control to switch the view signal to the external device you want to use. If there isn't a device connected to an input then there will not be a picture when you select that input.
  • Turn the "Input Lock" off if you are unable to view the signals for the external devices, such as a DVD player, or you are unable to view Channels 3 or 4.
  • Turn the "Channel Block" off or add the channel to the "Channel Add/Delete" feature if a channel has stopped appearing.
  • Turn the closed captioning off if there is an empty black box on the screen. The box might be empty if the channel or program does not have closed captioning.
  • Dcramer531
    Sometimes these things just need to be re-set. They run so long and the built in memory gets full and just like people they need a nap now and then. Glad this helped without a service call.
    I have a 50 inch Toshiba 50L4300U that has no picture but has sound. What board do I replace?
    Do this test first. With the TV on normally, shine a flashlight on the screen. look for a dim moving picture.
    1) If you see one, the backlight led driver isn't working.
    2) If you DON'T see a picture replace the T-Con board.
    You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
    Dec 21, 2016 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
    I have an 82" Mitsubishi DLP tv. I have replaced the lamps 3 times and just replaced the ballast. I am still getting 6 red blinks and 1 yellow
    I hate being the bearer of bad news, had the same problem, and I found out that the problem with DLP is that after so long, nothing that you do will fix it. A TV repairman offered me $100 for my set and I took it, that was 2 years ago and it still goes through bulbs and ballast several times a year. Now when i see him he always says I never should have taken that TV. It never plays long enough to sell it.
    On a liter note: 4k si approaching $1000 now, that's the way to go.
    Nov 26, 2014 | Mitsubishi Cinema WD-82740 82-inch 1080p...
    Orange light came on replaced the bulb after a day it blew out then replaced bulb again blew out now the light is red please help
    It sounds like it is not getting enough cooling. Clean the cooling paths. I am just taking a guess as I am not familiar with this unit.
    Jun 16, 2014 | Toshiba 72HM195 72-Inch Diagonal...
    Blue spots on screen
    Most likely the LCD panel is failing. These are "stuck pixels". Common with early LCD displays used on DLP TVs.
    Jan 22, 2014 | Mitsubishi 60inch 3-D Ready 1080p 120Hz...
    My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
    Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
    Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
    How do i change the setting to 1080p
    the tv will automatically switch to 1080p if its capable of displaying 1080p when the signal is supplied. currently only blue ray dvd players, playstation 3, and certain satelite recievers can output 1080p signals.
    Feb 06, 2010 | Samsung HL-S5087W DLP TV
    Problem with Toshiba DLP Projection TV Model #52HM84
    It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
    Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
    Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
    Our newly purchased Toshiba - REGZA 42" 1080p Flat-Panel LCD HDTV has a fuzzy "snowy" picture. Direct TV is our satelite provider.
    First check if this happens in other external video source as well, like DVD/CD/VCR, etc. If it does, get the set replaced under warranty.
    If it happens only with the Direct TV setup, try unplugging the set top box from both power supply and TV. Wait about a minute and reconnect. If the problem is rectified, the issue is with the setop box. Call Direct TV in this case.
    May 19, 2008 | Toshiba Televison & Video
    Televison & Video Logo
    90 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
