Question about Refrigerators
2002 dodge intrepid,fans dont kicks on.unplug the relay while car is running it work.turn the car of,turn it back it dont kicks on again. whats the problem.
    Scholar:
  • 189 Answers
Sounds like maybe a breaker, over heating, something is disconnecting and when you turn the key off it resets, then does it all over again .
check breakers,(if equiped) shorts,fan motors going bad pulling to much juice,?
I WOULD check the relay
Posted on Sep 24, 2011
Car runs 15min.then gets hot pull over for abt 3 min.turn car back on an it cools
you may have a problem with the cooling fans, ck to see if they are running when the car heats up, it sounds like they are starting up after you cyck the switch which would account for the quick cool down time, possible causes for this are coolant temp switch, fan relay, or pcm
Jul 25, 2012 | 2002 Dodge Intrepid
Car overheat when first run turn car off and back on and car run cool
You might need to replace fan assembly and/or thermostat. Mine was overheating only when stopped at traffic lights. Only one fan was working and would cause the car to overheat. Working great after fan swap.
Jun 20, 2012 | 2002 Dodge Intrepid
The car runs hot. the only way i can help the problem is by turning on the heat in the car, and this is the only way the fans kick on. i have replaced the thermostate, radiator cap, drain and refill...
Sounds like you may have a blown head gasket. Is your coolant level low and have you had to add coolant. Still sounds like you may have a cooling fan issue or maybe even a clogged radiator. what is the temperature difference from the inlet and the oulet of the radiatoe hoses? Anything less than 20 degrees and I would say the radiator is toast and you need a new one. And fix the cooling fan issue. But still dont rule out the blown head gasket especially if it over heated...
Jul 01, 2011 | 1996 Dodge Neon
My dodge 1995 intrepid will run but the fan does not kick on to cool the engine.once i stop the engine has to cool to restart.Problem is...
This is a common problem. Usually, the fan's RELAY has went bad. This relay can usually be found under the hood, somewhere in the engine compartment.
The relay is just a switch, and is activated by the engines temperature sensor.
It is just a pull-out, and plug back in little black box. usually, it is well labeled, and easy to find. it will be in a box, with a lid, and when you remove the lid, there should be several large fuses, and some little black boxes that usually say BOSCH 30A on them.
If you change the relay, and your fan still does not work properly, then the problem may be the temperature sensor on the engine, the wiring, or the fan itself may have went bad.
But, start with the relay switch, as it is the most likely culprit.
Good Luck.
Jun 20, 2011 | 1995 Dodge Intrepid
2002 intrepid 2.7 Im getting no crank from the starter and I dont hear the fuel pump kicking on when the ignition key is turned on, I do get power to the radio and dash, Ive checked fuses and replaced...
Under the hood, there should be a fuse block. Remove the cover and there will be a 20amp(i think) fuse that protects the fuel pump and starter circuit. I've run into this problem many times and every time it ends up being the starter that blows the fuse.
Jun 19, 2011 | 2002 Dodge Intrepid
Dodge intrepid 2.7 L 2002 the fans dont come on. overheats the water comes out of coolant resv. where do i start ? i changed relays both in fues box . i wonder about thermostat or coolant sensor
You fans might be bad test them. with a jumper pack and two wires leading from the jumper pack to the inside of the connecter on the fan were the wires from the car goes
Apr 07, 2010 | 2002 Dodge Intrepid
Hello! where are the relays for the turn signals on a 2002 dodge intrepid?
turn and hazard lights flasher is under dash on driver side. the best way to identify the component is go to the part store and ask to see a turn signal flasher. then you will know what your looking for. easy to replace, just unplugs
Jan 09, 2010 | 2002 Dodge Intrepid
2002 Dodge Intrepid accessory/starter relay problem?
Accessory position is turning key towards he driver. Ignition on is away 1 and start is away2.
  • Turn on your headlights, do they work? If not, chk batt terminals
  • If they do, try to crank the engine noting what the headlights do. If they go out, Chk the batt ground cable. If they dim, your batt needs a charge. If they dim and then come back bright when you back off the starter, the starter is bad.
  • Chk for loose engine to body ground. That would affect the accessories. Good Luck, _Ned_
Oct 18, 2009 | 2002 Dodge Intrepid
My 97 dodge intrepid 3.5L is running hot.
Most likely a bad fan relay, or a bad temp sensor. Does the fan come on with the A/C? If not, most likely the relay, if so, most likely the temp sensor.
Mar 13, 2009 | 1997 Dodge Intrepid
Intermittent overheating problem, 1996 dodge intrepid. New waterpump installed, new termostat installed, temp. sensor replaced , new overflow bottle with new pressure cap, all hoses replaced, system...
The relay. There is a black box on the right hand side of the engine at the top corner. It encloses all the relays. Make sure you are looking at the diagram well. Exchange the relays and remove the wiper relays and exchange them with the radiator fan relays. Start the engine, run it for 5 mins and see if they kick-start.
Jul 25, 2008 | 1999 Dodge Intrepid
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
