Question about Refrigerators
Frideidare model glhs37ehsb6 not cooling and making a constant beeping noise....what can i do???
    Genius:
  • 1,157 Answers
Hi bluesummerpe,
If your machine is not cooling and making a constant beeping noise, it might caused by connection with the door. There are several ways on how to correct this problem, either you add something to the door that will increase the connection or check if the compressor is running. Here are additional steps that you may apply on this issue.
1. Check the connection with the door. If it's a connection problem, try to add something to the door that will increase the connection. You can use a foam tab with a self stick side. Place it on the part of the door where the contact with the switch.
2. Check the compressor. If the compressor is running and you noticed that the machine is not blowing cold air inside the freezer. You may have either a restriction inside the sealed system or have a leak in the sealed system and all the Freon has escaped. It is like no Freon, No Cool.
3. If the compressor is not running, you need to check the motor. Either the motor is not getting power and that's why its not running, or its getting power and the windings inside are shot and that's why it's not coming on.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 28, 2011
My 2010 toyota camry hybird is making a constant beeping noise
You need to contact a repair shop, you have a brake failure, that is why the beeping it is warning you.
Nov 18, 2016 | Toyota Cars & Trucks
My fridge freezer is making a beeping noise and im not sure why its beeping The model is Elba ER169TRWH1
If the fan on the back is constantly running check to ensure it is not clogged, also make sure the door seals are not torn.
Dec 29, 2014 | Refrigerators
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
Under the glove compartment is a beeping noise?
what is the make and model and year ?
Dec 28, 2012 | Cars & Trucks
Frigidaire GLHS37EHSB6 beeping
The connection with the door and switch on some refrigerators is not good, you need to add something to the door that will increase the connection. A foam tab with a self stick side placed on the part of the door where contact with the switch is made works just fine.
Oct 16, 2012 | Frigidaire FRS3R5EMB Side by Side...
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Apr 04, 2010 | Electronics - Others
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
