Question about Car Audio & Video
I have a pioneer cd player im trying to remove but it wont slide out once i ve removed the screws at the front. How does it come out?
Benigno simeon corazon aquino
Posted on Mar 28, 2011
I have a 2005 Ford 500. I have twoo CD"S stuck in the player. How do I remove them?
If the two cd's which are stuck, if you can see that cd's then pull the cd with pliers.Its a two mouth pliers to pull the things out.The cd may get cracked/ break while removing.But if the cd's are not seen or its very hard stuck, then in that case.The cd player has to be removed out of dash.Yes it will be time consuming, and will not be very simple.But once the player is out, its not much to do.The cd player bottom has few screws to be removed.Once you remove the screws, the complete top assembly will get lifted.You can say" complete casing" will be lifted.Once the casing is out.You will visually see the cd, and you can manually slide the cd out and remove it.---------- ---------- Click this link for cd player removing procedure from dash :--------- http://whoisbyme.blogspot.com/2011/08/how-to-remove-cd-player-from-dash-of.html ----------- This will help.Thanks.Helpmech.
Aug 03, 2011 | Ford Five Hundred Cars & Trucks
VUP 0/9 KEEPS FLASHING DURING FIRMWARE UPGRADE NOW ITS MORE THAN ONE HOUR
I had the same problem when I made the mistake of trying to do a firmware upgrade via CD-R instead of the Network option. My player is no longer connected to the internet so I created a CD-R following the directions on Sony's site. The CD-R attempted to do the upgrade, but was stuck at 0/9 and I could hear the disc trying to read. The problem is the disc you created. You need to make another one. On the Mac, I used the Finder to burn the disc per Sony's instructions. That is what failed in the player. My second CD was created with Roxio's Toast Titanium, PC/Mac Data CD-R. If you have Windows, I would suggest using a commercial burning CD program, like EasyCD Creator and burn the two update files to the root level of the CD. Make sure the disc is finalized.
Next, you need to open the player to manually release the tray to eject the CD and swap it with your new disc. Remove the two back screws on each side. This removes the two side trim panels. Remove the two screws holding the top trim panel on each side. Then slide the top trim panel from front to rear to release the panel. If that doesn't work, open the CD cover door with your finger and then gently pull up on the top panel at the front edge to release the clips along the front, across the entire front edge. Then slide the panel back to remove it. Then remove the three screws at the front edge, and two more screws on each side. There is also one screw at the rear top edge. Remove the top panel. Then get a long paper clip. Looking at the front of the player, the manual eject hole is on the right side of the optical drive. Above the hole is an E engraved above the hole. Insert the paper clip straight into the hole and you should be able to push the release mechanism causing the tray to open. You might have to fish around a little. Slide the tray open and replace the disc with the newly burned disc (or obtain a disc from Sony for free through their website). Close the tray. You can leave the player open. Plug in the power cord and the upgrade will continue where it left off. It may take a minute or two, but you will see the VUP advance to 9/9, then finish. The tray will open and you can remove the disc. Close the tray and the player may reboot again. Once you see the No Disc message, turn off the player and pull the power cord. Reassemble in reverse order and reconnect your player to your TV and it will have the new firmware.
Oct 04, 2010 | Sony BDP-S550 Blu-Ray Player
How do I remove the CD/DVD hardware drive from Aspire 5520 laptop ..i want to replace it with a new one...where do i start first?
It will slide out once you unscrew one set screw. Flip over the Laptop and you will see several small screws. Gauge which one by figuring about 5.5 inches long from the edge of the front of the CD Rom and normally it is the middle or off just one inch either way.
If you try several screws it wont disrupt anything... just put them back of course.
Press firm while unscrewing...don't chance stripping and have the right size screw driver :)
Jan 24, 2010 | Acer Aspire 5520-5156 Laptop
TABLE ERROR SHOWS IN WINDOW
What probably happened is that some CDs fell off their tracks and are blocking the main wheelhouse from turning. To solve this you will need a philips head screw driver. First unplug the machine. You will need to remove the top of the unit (which slides off towards to the back) after removing the 9 screws (2 top, 4 side, and 3 top back). Once you slide off the cover, you will expose the wheelhouse and you should see the CDs that fell off. Simply take the cds out. Once you have taken out all the CD that came off the tracks, slide the cover back on and screw in the 9 screws. The CD player should work again. This worked for me and hopefully will work for anyone encountering this error.
Dec 01, 2009 | Sony CDP-CX300 CD Player
How do I remove front facia on my p.c so as to remove my cd/dvd drive
screws are located on the back,once these are removed casing should slide forward or up,once main casing is removed u will see the screws that hold the cd/dvd drive
Nov 17, 2009 | Computers & Internet
How to remove the faceplate on a Cambridge CD 740 clock radio
I just did this over the weekend, so, I'll expand on how to get there.
1. Pop off the speaker covers.
2. There are 4 screws on each side (not the speaker screws, the recessed screws). Remove those from each side.
3. On the back of the unit, there are 4 more recessed screws. You'll need to remove those, and separate the back from the unit (you may have to disconnect some of the wire connectors).
4. Flip the unit over (so the bottom is up). Remove the screws from the bottom, and remove that base. Note: you'll need to remove all the foot-pads as well (there is a screw under each).
5. Once you've removed that, you'll need to then remove the next set of screws from the "sub bottom" I believe there were 8 that need to be removed.
6. Carefully flip the unit over (you can put the "base" back on without the screws so it sits right).
7. At this point, you'll need to remove the top cover. You'll have to pry away at this one a bit, but it wasn't too hard. There is a connector for the snooze/mute button that I disconnected to make it easier once the cover was open.
8. Once the top cover is off, you'll see the CD player. There are two screws holding the CD player to the faceplate. Remove those.
9. There are three screws on the back of the cd player. Remove those, and you can maneuver the CD player at that point (I didn't need to take mine all the way out, as I just needed to get a quarter out of the player).
Then... gently reassemble. This is not an easy machine to tear apart by any means. Took me about an hour and a half to do it all (but I was also doing some trial and error).
Good luck! And be careful!
Jul 04, 2009 | Cambridge Soundworks CD-740 Clock Radio
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Jammed CD
Remove the top cover of the head unit with a screw driver. You may also need to remove the face and the front part of the unit. Once the top is exposed showing the cd inside the mechanical parts of the cd player, try to look for a mechanical lever that holds the cd in place. Usually in the middle(ID) of the cd. You'll most like would have to lift the middle part, then slide the the cd out. Check and observe the function of the mechanical parts. And last, try not to exert to much pressure or strain on the parts, because it may not function the same way once its reassembled. It's easy.
Nov 15, 2008 | Pioneer DEH-1600 CD Player
Clarion 635
I just fixed mine and the problem was one of the cartridge trays that holds cd's had come out and was sitting outside the cartridge and over the top of the assembly that "collects" the disc to play.
If you can easily remove the entire unit from it's mounting brackets, then I have a solution. It might sound tricky, but it's actually pretty easy.
Once you've removed the entire unit, place it on a table to work on. Remove the front plate (this is the part that has the hinged door on it to protect the cartridge and inside mechanisms) by carefully sliding a thin flat screw driver along the plastic edge where it connects to the metal box. There are several tabs that just have a friction fit holding it in place. Be gentle as to not break the top plate.
Once the front plate is removed, you'll find two very small black screws on each side of the metal box/case containing the cd player. (The top half of the case.) Once you've removed the four small screws, you can lift off the top of the metal case and expose the cartride and cd player. At this point, you'll probably see that 1 or 2 of the cartride trays has come out of the cartride and are sitting over the top of the cd player. Gently push the trays back inside the cartridge.
Once the trays are back inside, you can take the entire back over to the power card, plug it in and see if when you hit the eject button if the cartridge pops out. If it does, you're almost done.
Go ahead and slide the top half of the metal box/case onto the unit. Replace the 4 small black screws on the sides. Replace the front plate carefully. Remount the unit in it's original location. Plug it in and you're done.
Feb 03, 2008 | Clarion DCZ625 6-Disc CD Changer
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
right side to secure.
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
