I have philips hts 3520/94 it faces problem while playing mp3 files of higher bit rate like 320 kbps.
SOURCE: Req Help - - Olympus WS 320 M - Won't play some MP3 files
I found the problem, I believe. Check out page 80 of the user manual. I formatted the unit and ever after it would not play mp3s, even those I had previously used successfully. It no longer plays mp3s after formatting. I have heard that the limitation is on mp3’s at lower bitrates than 128k. Mine are all lectures at 56kbps. My solution is to recode my lectures from 56k mp3 to 64k WMA and it works. I understand that you can also recode to 128k mp3 but in my case this would make the files much larger.
I hope this helps.
Posted on Mar 01, 2008
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Posted on Oct 06, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Posted on Dec 08, 2008
srinivasb81
  • 51 Answers
SOURCE: Philips HTS 3565 system doesn't play MPEG-4(.mp4) formate.
HTS 3565 this model does not supports the MPEG4 video format, but you can play MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra, WMV all these formats.
Posted on Mar 27, 2009
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
Posted on May 27, 2009
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
Feb 21, 2016 | Alpine CDE-143BT Advanced Bluetooth CD...
Bit Rate
CD media We speak about AudioCD, not about MP3 collections: these are two absolutely different things. Audio CDs offer reference sound quality, because they capture everything without any clipping or compression. What concerns MP3 collections, they are just compressed CD tracks recorded on a CD. Music in AudioCD format has strict technical parameters, which cannot be changed. That's why it's possible to calculate the total length of a disc - 74 or 80 minutes (an album may be shorter, of course). You can copy music from a CD to your computer, but it's not very easy. In order to save your music to a hard drive, CD tracks should be encoded into any audio format. You can do it with various programs - for example, Windows Media Player, which can be found in most computers. The audio quality will depend on encoding options. The higher audio quality, the larger your audio files will be. However, this is already the next point :) Uncompressed media Digital data from a CD can be read 1:1 and recorded as a WAV PCM file. As no details are lost, this operation is fully reversible - you can record a CD from your files. It will be almost the same or absolutely identical (if you didn't break tracks into files) as the original CD. The advantage of this format is that it's lossless. However, from the point of view of portable devices, such files are too big: one minute of music in this format requires over 10 MB of disc space. Besides, WAV support is not available in all players: HDD players tend to support this format, while flash players usually don't. Lossy compression There exist methods to compress music, when some audio data are lost. For example, MP3, WMA, OGG, AAC, etc. It's these formats that are supported by all modern players. But this support is limited. For example, any player supports MP3. WMA is supported by 3/4 of the modern devices. However, only 30-40% of modern players support OGG and AAC. Lossless compression An encoding program can compress original audio from a CD several times. However, the file size is relatively big - a usual CD can be compressed twofold. However, original audio is not clipped. While lossy formats just sound like the original audio CD, lossless formats provide original sound, which is compressed to take less storage space. There are several lossless codecs and formats. The most popular is the format used by Apple - it's supported in all iPods but shuffle. You may also come across such formats as FLAC and APE. These formats are especially promising from the point of view of their top audio quality - they are no worse than WAV PCM, but they take up 50% less storage space and they support tags (we'll touch upon them below). Regardless of a format, music files differ by compression quality. The main parameters here are bit rate and sampling rate. Bit rates vary much in music files. The higher the bit rate (all other things being equal), the higher the audio quality. The highest audio quality is provided by bit rates starting from 128 Kbps and higher. Lower bit rates are used only when audio quality is not critical, for example for voice recording. Besides, it's agreed that 320 Kbps hardly differs from the original audio track. However, it's a subjective factor, which depends on a given person, ear for music, and sensitivity. By the way, the bit rate of audio CDs is 1411 Kbps. As we can see, there is a great difference between compressed and uncompressed audio. Audio file size grows proportionally to its bit rate. The lower the bit rate, the smaller the audio file, the lower audio quality, and vice versa. Let's describe the notions of bit rate and sampling rate.
Bit rate shows how much data is required to encode one second of an audio file. So, when the bit rate of a file equals 256 Kbps, it means that each second of this audio file takes 256 Kbit of memory. So you can calculate the size of a music file, if you know its length and bit rate. Another definition of this term is a bitstream. It's often used to describe audio microcontrollers. It's easier to understand this term from the point of view of interface throughput: how much bits are processed (go through a given interface) per second. It's impossible to say which bit rate to use to encode audio - it's a subjective matter. One user will be always satisfied with 128 Kbps, the other will grumble about 320 Kbps.
Sampling rate—it resembles video resolution: the higher it is, the more details you will see. What concerns sampling rate, the higher it is, the more distinctly a file sounds. So the higher the better. The optimal quality is usually provided by the sampling rate of 44100 Hz (it's often called 44 kHz). This value is not chosen at random - according to the sampling theorem, a sampling rate of a signal must be at least twice as high as the rate of the source signal (if you know physics well, don't write angry emails to us, we simplified it deliberately ;)). As a human ear distinguishes sounds from 20-30 Hz to 20-22 kHz, we should use 40-44 kHz for digital audio processing. The standard of professional equipment is 48 kHz - with a little safety margin. But when the AudioCD standard was created, its authors did not want to compete with professional equipment, so the sampling rate was cut down to 44 kHz. Computer formats support even higher values. But as most music tracks are copied from AudioCDs, there is nothing surprising about this value being the widest spread sampling rate.
This theorem gives only a necessity criterion, not a sufficiency criterion. That is, we know for sure that if we don't provide the twice as high sampling rate, the audio quality will definitely be bad... But we don't know whether it will be good, if we do. And we don't know the exact sampling rate to ensure good audio quality :) That's why the 48 kHz sampling rate is used in DVDs and professional audio equipment, and HD audio (for example, SACD or DVD Audio) supports sampling rates of 96 kHz or even 192 kHz, because even 48 kHz may be insufficient. However, there is no need to support these excesses in portable players :)
What does it all mean in practice? Here is a ballpark statistics for a 4.5 minute audio file. We'll show you how many files your player can store depending on the quality of these files and capacity of the player:
Quality and size of an audio file/ player capacity 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 128 Kbps - 4.3 MB 120 240 475 950 1900 3800 192 Kbps - 6.48 MB 80 160 315 630 1260 2520 256 Kbps - 8.64 MB 60 120 235 470 940 1880 320 Kbps - 10.8 MB 45 95 190 380 760 1520 The speed at which a player can save data into its memory is not a key factor, but it's still important. The higher the speed, the faster you can copy files to memory. The usual speed is 2-5.5 MB/s for flash players and up to 15-20 MB/s for HDD players.
Prices for flash memory are constantly decreasing now. When you choose between identical players with different memory capacities, you should keep in mind that twice as much flash memory does not mean twice as expensive player, because the player itself also costs some money. So you should make up your mind whether to pay a little more for double memory capacity or save it.
8 bits = 1 byte
1,024 bytes = 1 Kilobyte (Kb).
1,024 Kb = 1 Megabyte (Mb).
1000 Mb = 1 Gigabyte (Gb).
Modern computers can store anywhere from 5 to 100 Gbs on their hard drives. Why would you need to worry about the file size of your digital audio with so much space available? Well, your computer needs a good chunk of its hard drive to store the operating system (Windows, Linux, etc.) and instructions for running things like your modem, your internet browser, and your email program. So space is often at a premium. You’ll see.
May 20, 2008 | Tascam DP01FX All-In-One Recording Package...
WHEN I DOWN LOAD FILES TO MUSIC IT SAYS IT CANT SUPPORT THE FILE I HAVE HAD PROBLIMS WITH THIS UNIT SINCE I GOT IT.
go to your user manual. The format that the songs are in may not be supported. for example: if your player is a mp3 play the song have to be mp3 formate. it wont play WAV or AAC/MP4. looking at your manual found online here
http://www.p4c.philips.com/files/s/sa5285_37/sa5285_37_pss_aen.pdf
Compression format: MP3, WMA, AAC
•ID3 Tag support: Album title and artist name
•MP3 bit rates: 8-320 kbps and VBR
•WMA bit rates: 5-192 kbps VBR
•WMA sample rates: 8, 11.025, 16, 22.050, 32, 44.1, 48 kHz
•MP3 sample rates: 16, 32, 44.1, 48, 11.025, 22.050, 24, 8 kHz
•Digital Rights Management: Windows Media DRM for Portable Devices, Supports download & subscription music services
these are the formates supported. also make sure the music is in the proper folder
Feb 24, 2010 | Philips GoGear SA5285/37 Digital Media...
What videos can it play?
Any videos that are in the proper format.
Download and install the "Sansa Firmware Updater", connect your Fuze, and run the Updater. Besides making sure that your Fuze has the most up-to-date firmware, it'll allow you to download the "Sansa Media Converter", which can convert most videos directly onto your Fuze in a format that it can play.
Jan 27, 2010 | SanDisk Sansa Fuze MP3 Player
How do i put videos on my walkman?
Your Walkman Video NWZA818 MP3 Player video capabilities is as follows:
Video Format : MPEG-4 (MP4)
Video Bit-Rate : 128 kbps
Max Video Resolution : 320 x 240
Convert your movies using a video converter under these settings for your Walkman to be able to view the file.
Jan 07, 2010 | Sony Walkman Video NWZA818 MP3 Player
I have just bought a new motorola zn200 yesterday and it is not able to receive mp3 files from my hp pavilion dv6000 laptop through bluetooth. it starts receiving and then in the middle it disconnects....
You have amemory space of 10MB in your phone & 20 MB in mass storage device. When you transfers any files through bluetooth, it goes to phone memory. so I think this problem occured due to insufficient memory. free up your phone memory and try again.
Jul 17, 2009 | Motorola Mobility MOTO ZN200 Cell Phone
Not playing song all the way and skipping
Make sure the songs are not samples-only first.
"File Format Not Supported" - SA6045/37
The file format not supported message means that the type of file you are trying to load into the GoGear is not compatible with the GoGear. There are no GoGear's that are compatible with iTunes. As far as WMA files are concerned, the GoGear's vary wildly. If the WMA file has a bit rate higher than 192 kbps (which is quite common nowadays), it will not work. If you actually have an SA6045, then make sure the license on the WMA file has "transfer rights," or that the license has not expired. You can check this by right-clicking on the song, selecting Properties, and looking at the tab that says "license" or "digital rights management."
If you find that you are using an incompatible format, convert the songs to mp3 format. If the songs came from CD, use Windows Media Player to re-rip the songs in Mp3 format. You can do this in Windows Media Player 11 by highlighting the "Rip" tab, pulling down the drop down-menu by clicking on the little tiny arrow that appears underneath the word "rip," and selecting "format", and then "mp3".
-Tha Mp3 Doctor
Nov 02, 2008 | Philips GOGEAR SA6045 MP3 Player
Mp3 problem
Check the files are compatible with your player.
1- check the manual to see what file types it will play.
2- ensure they are within the players bit rate range. If your files were samples at 320 kilo bits a second (kbps) then this may be to high for your player.
3- ensure that the files are not copy protected. eg. DRM
4- check the manual to see if you need to set up folders for albums. Some players cannot cope with to to many files just dumped onto them, they need to be organised in folders. This is because of the filing systems they use.
I'm sure one of the above is your problem. If you still have trouble after checking the above I can make further suggestions.
Regards,
Spare head 2.
Jan 04, 2008 | Philips GoGear HDD075/17 MP3 Player
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Keeps restarting
Joybee 130 supports MP3 files in bit rates 8~320 kbps (sample rate 8~48 Khz); mybe this is the problem...
Nov 20, 2005 | BenQ Joybee 130 MP3 Player
67 people viewed this question
 Grubhead
Grubhead
