Question about Ovens
Have inglis glass top model IDP86804 the one element on the front big one will not go to low, seems to stay on high gets red hot even when turned down to 2 or 3 is it the switch or the element.. Thanks
5 Suggested Answers
  • 1314 Answers
SOURCE: Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Posted on Dec 30, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 14 Answers
    SOURCE: Oven top element gets SUPER hot without warning
    the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
    Posted on Feb 14, 2009
    • 9 Answers
    SOURCE: Thermador SC301T heating elements not working (top
    Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
    Posted on Dec 11, 2009
    Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
    The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
    Oct 16, 2017 | Bosch Ovens
    I have an Inglis IEE31301. The stove elements work but the oven does not heat up. I cannot find any manuals for this model, and I don't know if it has a oven thermal fuse or a regular fuse that needs...
    ovens r simple - turn sw on, element heats up. Except ovens usually have timers on them.
    start by verifying NEITHER bake or broil works.
    If one does - high probability the other element needs replacing.
    If neither do u will need an ohmmeter to trace the open back to the plug. There is a possibility BOTH elements r out, not very likely, but start by ohming out both. Don't know what resistance is but it will be less than 1000 ohms. Without a schematic - and u may find one inside the unit - u will have to physically eyeball the wiring.
    Feb 23, 2015 | Ovens
    Fisher and Paykel Paprika Oven Top Elements Full hot!!
    No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
    Mar 17, 2012 | Fisher and Paykel Ovens
    Is the top heating element inside the oven supposed to get hot even if not set on broil?
    Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
    Apr 06, 2011 | Kenmore Ovens
    My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
    If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
    The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
    The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
    If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
    to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
    If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
    Nov 27, 2009 | Kenmore Ovens
    Vent fan stays on
    The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
    Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
    Element will not turn off
    Sounds like the contacts inside the switch have welded themselves together. You will need to replace the switch. (the one that you mentioned "clicked" to off) If you like, post an Ask Me with your full model number and I will look up the part number for you. This is a fairly easy repair.
    Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    GE Stove:
    The symptoms suggest that the control relay has welded contacts. This was a result of the element failure producing a surge of current. You will need to replace the electronic control. Another possibility is to contact the folks at www.cgiltd.com.
    They offer a repair service.
    Jan 22, 2008 | GE Profile JTP18 Electric Single Oven
    Oven heating element stays on
    If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
    Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
    Ovens Logo
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
