Question about HP Photosmart C6180 All-In-One InkJet Printer
Error 0x 18a0401 - HP Photosmart C6180 All-In-One InkJet Printer
    Guru:
  • 89 Answers
Try link below for specific steps in troubleshooting
An '0x ...' Error Message Displays on the Front Panel When Printing
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=1153494&tmp_track_link=ot_search
Issue The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' error 0x 18a0401 - c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error:
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with therror 0x 18a0401 - c01424575.gifimg src="http://i.fixya.net/uploads/images/c01424575.gif" alt="c01424575.gif" class="h_mi" /> ). Figure 2: Example USB connection (your product might not look exactlerror 0x 18a0401 - c01651067.gif this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does nerror 0x 18a0401 - c01602202.giflly turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , click here to view additional printer support options starting as low as $20.
Posted on Mar 28, 2011
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
Tip
0x error
No matters which printer you are using if you get any error like 0x*****
please please donot perform any steps...please call HP teach support on 1800-474-6836...and if its needed they will replace the printer..
on Jan 21, 2010 | Office Equipment & Supplies
The error says "Application has generated an exception that could not be handled. Process id=0x (a series of numbers that change), Thread id=0x (numbers that change). Click OK to terminate the applica
did you add any new hardware or software just before this error started. If this is a Windows PC you can go into the safe mode and remove the bad software. You can also (if you can) remove or disable the hardware. Reboot into the PC as normal and see if you are still getting the error.
Jul 31, 2013 | Computers & Internet
Print error
Try the cleaning cycle. Try removing the cartridges and reinserting them.
May 07, 2012 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
STOP:c0000005 The instruction at 0x%081x referenced memory at 0x%081.The memory could not be %s. This message appearing on laptop screen - cannot do anything with it now!
There are a lot of cause to this error message. But mostly software. If you back up your files. I suggest to perform factory image recovery and restore the computer to factory default setting.
Jul 21, 2010 | Dell Inspiron 6000 Notebook
I have ink error OXC18aOOO1. Any idea of what I should do or how to clean the printer head, it won't pull over so I can get at the printer head. Thanks David
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET OR THE PRINTER NEEDS TO BE SERVICED
Mar 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Blue screen of death
Hello
Well, that spesific error mesage is because of a hard drive failure. I notice that this same problem occurs more in portable devices, such as laptops. The thing is, that if the laptop was droped during the days previous of this error, the mechanism will still run but the disc will have so many bad sectors that you will not be abvle to use it anymore.
I would suggest that you try formatting the drive first and see if it works, otherwise get a new drive. Hope this can help you.
Best regards
Andrea
Nov 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Blue screen appears have to run in safe mode, dell inserion laptop with vista
The blue screen error will have a code something like 0X******** (0X*******............). You can either comment the error code here or you may also check the same in the microsoft website. It will have a solution as well.
Good luck !
Aug 28, 2009 | Dell Computers & Internet
A problem has been detcted and windows had been shut down to prevent damage to your compuetr
This is a windows stop error. Are you running windows XP?
If it is the first time you have seen it you can try restarting and it may never appear again. If it does:
At the bottom of the screen you will see some text saying STOP ERROR: 0x000000?? (0x???????? 0x???????? 0x???????? 0x????????)
Look at the code prior to the brackets 0x000000?? - write it down and google "STOP ERROR 0x000000??".
This will let you know what is causing the STOP error. Very common reasons for this are component reseating required and disk-checking. You can run a diskcheck through the Windows Recovery Console (can be installed to hard-disk - simplest way is to install combofix and follow the onscreen instructions - or run from your windows installation disc).
Jul 23, 2009 | Dell Dimension 9200 PC Desktop
HP Photosmart C6180 All-In-One InkJet Printer Logo
163 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
