Question about Hoover Washing Machines
Hi, I have a hoover 550 electro economiser dual spin front loader that is leaking water. The seal underneath (big grey seal) has a tear in it. What is this seal called and where do I get a replacement? Where can I download a manual / spare parts for this machine?
SOURCE: GE Front loader washing machine
renew your door seal
Posted on May 27, 2007
jsrock516
  • 5911 Answers
SOURCE: If I replace my bellow seal in my front loader will it leak?
It will not leak if you install it correctly. Click on the following link for step-by-step instructions on how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Inspect the new bellow PRIOR to beginning installation. Make sure the inner clamp that attaches to the wash tub is snug and not overtight. Also, make sure the rubber on the bellow that fits over the dispenser tube in the door area is installed past the flange (raised area on the tube). These are the common points that leak. Please let me know if you need further assistance. I hope this helps you.
Posted on Jul 12, 2008
  • 3600 Answers
SOURCE: Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Posted on Sep 05, 2009
apart4u
  • 213 Answers
SOURCE: LG Washer leak, small tear in door seal
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
HansPP
  • 2510 Answers
SOURCE: My Hoover Front loader is
If the hole goes right through the seal it could be the cause, but I am inclined to think it is a vent hole for the seal and that a leaking seal will come out on the front panel. Remove the machine back and check the pump seals and the hoses, it is more likely those at that age. Take care, there may be live terminals and connectors inside the back of the machine when the power is on.
Posted on Mar 27, 2011
Leaks left side underneath..only on rinse cycle
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Apr 03, 2015 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
My Hoover Front loader is leaking water from underneath the machine. It is NOT the taps..I believe it could be the rubber seal just inside the door of the machine, as it has a hole in it. Could this be the...
Mar 27, 2011 | Hoover Washing Machines
MANSFIELD TOILET KEEP LEAKING
I'm not exactly sure where the seals are that you are describing. I'm thinking that you might need to shut the water off, unbolt the toilet from the floor, and replace the big wax toilet gasket underneath.
That's the main seal for internal plumbing in the toilet, unless you're talking about the toilet leaking into itself and wasting water. In that case you might need to simply adjust the mechanism (float, flapper valve etc.) to get the right setup.
I'm not sure I completely understand your problem though.
I hope this has helped anyway.
Lyle
May 03, 2010 | Mansfield Plumbing Products MANSFIELD 3/8"...
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer leaking from underneath
MY FIRST THOUGHT WOULD BE INSPECT THE BIG GREY DOOR GASKET FOR A CUT OR A TEAR. LOOK CLOSE. THE WHOLE MAY BE TINY
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Westinghouse Washing Machines
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
Sep 05, 2009 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
