Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
After cleaning out the crud accumulated in the dishwasher, I forgot to put back the round silver piece on the bottom when I was rinsing it out. :O Then we got an F1 error code. Figured out how to remove the bottom drawer and dry it out. The code went away, but after two quick test runs of the top drawer, water is leaking into the bottom drawer and onto the floor. Clearly, I caused the problem. What would could be causing the leak? What should we check next?
  • Gabrielle Mar 28, 2011
    I will check! Still, it shouldn't leak if we left it out, should it?
  • Fisher and P... Master
  • 528 Answers
The position of the dishes tray in the drawer , make sure that the spray arm not tuching it wile it spin
Posted on Mar 28, 2011
    We ran it both with and without dishes. No dishes were touching the spray arm. It flooded both times. Thanks though!
  • 911 SERVICE TODAY
    911 SERVICE TODAY Mar 28, 2011
    no not the dishes the dishes tray there is a part of it on the left side that if it not put right the spray arm will tuch it
How do you clean filter on whirlpool dishwasher du1055xtpq4
The filter will be located in the bottom of the dishwasher. There should be a round cylinder. Just pull it up. Rinse off the screen carefully so you don't poke a hole in it. If you do you will need to replace it. It may be clogged with a hard white solid. This is from hard water. Just soak in a drain clean for an hour to soften and carefully scrape off with a wooden tool. The other filter is a larger 1/2 circle screen. Pull it out and rinse off. Finally - very important - check to make sure your washer drains. If you don't hear the sound of water being drained out of the washer check the anti-siphon cap that sits on your sink counter. Pull off the silver cap to expose the tube cap. Use needle-nose pliers to remove the plastic cap. Debris gets trapped in there and doesn't allow the dishwasher to drain.
Aug 05, 2014 | Whirlpool Dishwashers
LG Dishwasher Leaks
Hi Jim,
I recently noticed exactly the same symptoms with my
LDS4821 which I think is a similar age.
After a bit of head scratching and a similar door cover
removal exercise I also figured it must be coming via
that round vent and then on down the plastic duct that
runs to the bottom left vent in the door that you
photographed.
Here's what I did which has certainly fixed my leak:
1/ First I cleaned around the inside of the round vent
on this inside of the door. Specifically I removed all
the accumulated crud around the edges of the circular
yellow rubber gasket piece at the center of the vent on
the inside the machine (your first photo). I did this
after untwisting the circular grill that holds that in
place - my vent unit behind that grill also wiggles
around by the way, but only when that round grill has
been unscrewed! I was careful to make sure that the unit
behind the grill was seated properly again when I
twisted the grill back on to tighten it and hold it in
place again. I actually checked this with the front of the
door taken off for this second step below to make sure
there would be no issues with the outer seal around that
vent unit (where it presses up against the inside of the
metal door to form a seal when the round vent grill is srewed on).
2/ This I think is actually the critical step. I noticed
a second black hose that runs down from the plastic vent
structure almost directly behind where the round grill
is positioned on the inside of the door. See the picture I've attached re. the tube I am talking about. Looking at this I figured it's some kind of internal drain (that seems to drain back into the washing compartment itself at the
bottom). Given that I'd seen some crud on the
yellow rubber gasket I wondered if some crud had also
blocked the top of this hose, leaving any water that gets in there to
then run on down and out of that vent at the bottom
instead. Sure enough when I employed the crude (but
apparently effective!) technique of sucking on the
bottom end of that tube to see if it was clear, I soon
enough felt a blockage break and I just had time to aim
the tube away before a bunch of grey crud came sweeping
down the tube, followed by some clearer water. By the
looks of it you might be able to unclip the hose clamp
at the top and do it somewhat more professionally to
avoid the risk of a mouthful of 2-3 year old dish crud
in your mouth!
I've just run it through a full 'normal' cycle and it's
back to working normally again - no more leaks.
Well dishwashers may **** at times, but apparently I do
too...
Hope this helps.
-Dan
Jul 04, 2012 | LG LDS4821 24 in. Built-in Dishwasher
Espresso not coming out spout but going into tray
I had the same problem, coffee coming out of one nozzle or sometimes from the middle btw. the 2 nozzles. It turned out to be dirt in the front unit that holds the nozzles. I removed the silver plastic cover (which says BOSCH), it can be pryed open left and right from the bottom to the top, the front part will come off, see picture. Then I detached the hose from the black dispensing unit. Then I removed the black unit that has the nozzles on the bottom. This unit had dirt inside but cannot be opened further. I rinsed it often and detected black crumbs in there that I mushed with a toothpick to get them out. That fixed the problem.12_6_2012_1_37_05_am.jpg
Apr 21, 2011 | Bosch Benvenuto B30 Espresso/Coffee Maker
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
I would like to clean off the calcium deposits that are in the dishwasher. How can I do this or what product should I use.
there are few things you can do to remove the calcium deposits.....
Change the detergent you use. Powdered dishwasher detergent is more efficient in removing grease and oil than gels. Decreasing the gunk left on surfaces may help slow lime scale buildup.
Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • 2 Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
  • 3 Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
  • 4 Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • Read more: How to Remove Lime Deposits in Dishwashers | eHow.com http://www.ehow.com/how_5611602_remove-lime-deposits-dishwashers.html#ixzz0wtABvYq2
    Aug 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Type of rinse agent needed for dishwasher
    The rinse aid container in the door is quite large. Maybe you just stopped pouring too soon.
    Sep 14, 2017 | Westinghouse 24 in. MDB421 RF Built-in...
    Always little crumbs in glasses on top rack
    Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
    Feb 13, 2018 | GE Nautilus 24" Built-in Dishwasher
    Washing less effectively over time
    I just had my Maytag dishwasher serviced. It was getting less and less efficient over time. The items on the top rack weren't even getting clean. The repairman showed me the problem: the water was not spraying very well at all.
    There's a round water filter at the bottom, underneath the spray arm. It's a hard plastic mesh ring, maybe eight inches across and four inches high. This ring was completely covered in garbage. Gunk, pieces of cellophane, you name it. No way water could get through it. I was amazed to see how clogged it was.
    He took out the ring, scrubbed in clean, and put it back. The water now sprays like there's no tomorrow. Practically like new.
    Feb 23, 2010 | Maytag MDB7100AWB Dishwasher
    Water didn't drain, left in bottom of washer tub
    I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
    Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
    JDB1100AWS not rinsing
    if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
    Jan 11, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
    Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
    248 people viewed this question
    Top Fisher and Paykel Dishwashers Experts
    Brian Coughlan
    Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
