Question about Logitech 967437-0403 Keyboard
When i type a sentence and make a mistake and want to add a new word into my sentence the space bar and any keys i touch type over my existing print. how do i correct this.
    Scholar:
  • 84 Answers
You need to toggle your overwrite/insert setting.
All you have to do is hit the "Insert" button on your keyboard. Hitting it once will set your type settings so that new text will be inserted instead of overwriting existing text. Hitting it again will toggle it back.
Posted on Mar 28, 2011
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
My Smith Corona Galaxie 12 malfunctions by automatically adding spaces between letters while I type. How do I fix this?
Did you ever get a resolution to the added space problem? I just purchased an old Smith-Corona Super Sterling and it is doing the exact same thing.
Jan 11, 2013 | Smith Corona Office Equipment & Supplies
I am typing off the laptop keyboard itself and as I am typing it jumps back into a previous sentence or previous paragraph
Most likely culprit:
Do you have the finger touch-pad turned on?
Chances are you're brushing up against that, high static will increase the likely hood.
I don't even have to touch mine.
If you have a button to turn it off - great! Turn it off while you're typing.
I've seen some that lack this feature. I'm not sure if it can be disabled in the task bar; or if you'd need to disable the device through the hardware/device manager.
Another option is to just make sure your hands/wrists are elevated -- They really should be anyway to avoid carpal tunnel.
Other possiblilities:
Hitting the: home, pg up, pg dn, and/or end keys -- Arrow keys as well, will do it.
Some sort of software malfunction. -Perhaps, glitch or compatability issue.
Virus/someone's accessing your computer - Usually they don't just play around with your sentences though. ;-)
Broken keyboard.
Hope this helps!
Alex
Mar 23, 2011 | Computers & Internet
My typewriter stops typing in mid sentence and then i have to tab and backspace in order to type again.
It sounds like the R. margin is set there. touch mar rel key, space to the R. end touch R. margin key.
DickyO
Aug 11, 2010 | Olympia Supertype 330 Typewriter
Have HP Patvilion Entertainnent - Vista, typing
the solution is very simple!!!!!! it might help u out(99% chances): wat must be happening is, while typing u r touching the touchpad by mistake which is making the cursor move back.... This time type & ensure that u r not touching the touchpad & u will notice that the problem wont reoccur....or u can also turn off the touchpad while typing so that even if u touch the touchpad by mistake, it wont make the cursor change its location..... try this & let me know if it resolves ur ongoing issue by rating this solution...
Jul 11, 2010 | HP Computers & Internet
How to use the margin release for Brother EM-530
Is Margin Release on it's own separate button on the EM-530? If so, then to move beyond a margin:
  • Use Return or Tab to go to the left or right existing margin.
  • Touch Margin Release.
  • Use the Backspace or Space bar to go beyond the margin in question.
  • If you want to set a new margin, then go to the location you want to have it and touch the Left margin or Right Margin button.
Some models may require the CODE key to access one or more of these functions. If the function name is not printed on the top of the key, but on its front or on the surrounding plastic above the button, press and hold the CODE key while touching that button (just as you hold the Shift key to type capitals). The CODE key might possibly have a different name; chances are it's color will match the functions it works with.
Jan 05, 2010 | Brother EM-530 Typewriter
HP laserjet p2015 printing problem
How old id the printer. What OS do you use. What driver version do you have and does the printer have any accessories fitted?
Jul 07, 2008 | HP LaserJet P2015 Printer
Printer prints just part of sentences
Heeheehee do I feel stupid I just checked the printer for the upteenth time and finally found the problem.
I had a piece of paper (sticky price tag paper ) on the ink track so that was what was causing my problem. It was covered in ink LOL.
Wanaka
May 06, 2008 | Lexmark X1240 All-In-One InkJet Printer
Logitech 967437-0403 Keyboard Logo
108 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
