Question about Sony Playstation 3 (PS3) Console
Playstaqtion 3 lights come on but after checking wires the screen will not come on sometimes it show little speckles of light but no words just black screen and line 1 doesn't disappear from screen. Any tips on what I can do other than hold the button down and wait for 3 beeps, cause I have tried that over and over..
    Novelist:
    Sniper:
  • 51 Answers
Hi Loretta69,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Posted on Mar 28, 2011
I have a Sanyo PLC-XP50 projector and my words on the screen are showing up white with purple speckles, when I want them just to be white.
there are a lot of dust on the Lcd panel
3 panels (red ,blue,and green) in the Projector
purple speckles means that the dust on the Green ,
1,pick the Lcd prism from the projector
2,clean it by putting it into water,with some cleaner
3,dry it with a hair dryer
4,ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 19, 2014 | Sanyo Office Equipment & Supplies
I am trying to install a Pass & Seymour Harmony fan speed control switch. It has 2 red wires and 1 black. I hooked up the power to the red line and the black leading to the wiring for the fan. No...
Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
http://waterheatertimer.org/pdf/Pass-and-seymour-3-way-3-speed-fan-control.pdf
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
Sep 25, 2012 | Electrical Supplies
Words on screen are 3 different colors blue red green, no picture just black screen when changing input and input channel words showing in diff colors
YOU may have two problems, 3 d picture or letters suggests convergence problem, Tell me more, all inputs have no function?
The more you tell me the better I can help.
I am expert with these sets and know them well.
SD TECH
Nov 06, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Looks like a black thumbprint blocking 1/3 of the screen. No LED's lit on front of TV. Started as black dots, and filled in almost completely. Initial lamp lasted 2 years. The replacement lamp lasted 3...
It looks like DLP chip is failing. It is installed on DMD board that in turn belongs to optical engine. Issue should get progressively worse. If you look at screen up close - you see that "tumbprint" consist of little small dark-gray squares, some of them flickering.
Cheapest solution - to replace DLP chip. instead of replacing whole optical engine.
This repair have to be confirmed (by running test patterns in service mode first) and done by professional.
Repair could cost aroung $400.
During procedure I would recommend to turn ceiling fans and other air blowing devices off. Single little dust speckle landing on the chip surface will ruing all effort and same amount of labor have to be applied yet again just to get rid of it (been there, done it).
Good luck.
Russ.
Apr 06, 2010 | Samsung DLP HL-P5663W 56" TV
How do I reset playstation 3 to its origanl
playstaqtion 3 lights come on but after checking wires the screen will not come on unable to start the playstation 3,
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
My Syncmaster 205BW monitor has speckles & button's don't work.
Your monitor is defective. The speckles are actually dead pixels and the problems you're experiencing have to do with a defective board. Basically, it's dead, you need to replace it.
Jun 02, 2017 | Samsung SyncMaster 204B (Silver, Black)...
Blue spots on Sony High Definition 41 inch tv.
There are tiny screens at the top and bottom of the lightbulb (XL2200) that allow air for cooling over the lightbulb. It appears that if air flow is restricted the heat is not able to escape. The light source is in direct proximity to another mirror like device called the integrator lighting system polarization changer element. This may have gotten a little hotter than normal and is changing how the light is passing through to the tiny LCD's which make up the light engine. Creating the small areas of lavender light we are seeing.
I myself have replaced this bulb and now will check every months to vacuum the dirt off the tiny screens.
Apr 26, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Sep 21, 2008 | Electrical Supplies
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
